| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm looking for a 100K, quad-section, audio taper pot, to replace one in a vintage tube amp. Any idea where I can get a decent one, that won't cost a mint? Been looking, but haven't come up with one yet, that didn't require buying 1000 of them...
Thanks! Regards, Gordon.
Speaker Design, Restoration and Repair- since 1985. |
#2 |
And if that isn't hard enough
I also could use a pot, with two 100K sections, and two 1M sections, also audio taper... Regards, Gordon.
#4 |
For the four-section, your best bet is probably a four- or six-deck motorised Alps RK168-series (RK16814 or -16 respectively). There are a couple of reputable sellers of these on ebay. Alps also makes the blue RK27 in a quad version in 100k (RK27114) but whether you'd be able to actually find one for sale is a completey different question.
The second one you describe is probably only available as a customer order, so if you don't need 1 but 1000 then you might be able to get someone to make them for you /U. |
#5 |
I have 2, both 250k, audio-taper with tap. One pc-mount, one wire. PM me if you could use one. Shafts are 6x25mm. E
| Old Japanese Pot Marking A=Log taper? | pjanda1 | Parts | 4 | 5th February 2010 10:24 AM |
| 100K pot in a preamp? | G | Tubes / Valves | 5 | 15th May 2008 02:41 PM |
| WTB: 10K Alpha pot, dual log taper | KT | Swap Meet | 3 | 11th May 2006 03:01 PM |
| Effect of using 50k pot instead of 100k pot in tube preamp? | KT | Tubes / Valves | 5 | 17th February 2006 09:56 PM |
| Log taper digital pot | Jocko Homo | Digital Source | 2 | 17th April 2002 03:18 AM |
| Page generated in 0.07791 seconds (75.92% PHP - 24.08% MySQL) with 10 queries |
