Coupling Capacitor - Pls Help - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th December 2011, 03:18 AM   #1
tony Ma is offline tony Ma  United States
Default Coupling Capacitor - Pls Help
I have JP200 and just solved the problem that I got (excessive noise and un-balance between the channel)
Now I am thinking to change the capacitor
I am leaning on these capacitor only
Mundorf Supreme Silver oil
Janzten
Auricap
The capacitor that I need is .47uf (Coupling Capacitor) and 1uf and 2uf
Due to the budget, I am thinking to use .47 with Mundorf and remaining using Auricap.
Currently this pre-amp using solen capacitor and I have tungsol reissue
I feel that the sound is that open
Here is my set up
CD - VALAB Nos DAC (I did modify the capacitor) - JP200 - B&K ST-140 and Speaker is DIY from STATEMENT SPEAKERS by Jim Holtz
Here is the schematic
http://analogmetric.com/download/JP2...0Schematic.pdf
Any input pls....
tks
Old 16th December 2011, 03:31 AM   #2
GloBug is offline GloBug  Canada
Banned
"Due to the budget, I am thinking to use .47 with Mundorf and remaining using Auricap."
I would go that route if you must. I can't really comment on them and would like to try a few myself.
Keep in mind that the cap upgrade could exceed half the value of your amp.
That's not the end of the world for a hobby by any means, although that money could be put towards a better unit with plain caps.
Old 16th December 2011, 04:32 PM   #3
ruffrecords's Avatar
It does not matter which of those coupling capacitors you use, there will be no discernible difference in the sound.
Cheers
Ian
Old 16th December 2011, 04:42 PM   #4
Palustris's Avatar
If you have a cap on the output of your DAC there is no need for the one on the input of the preamp so eliminate C1a/b. That will save a few bucks. Second, 470nF coupling caps are way oversize. 100nF will give a -3dB point of 3.4 Hz. Forget the 10nF cap as it is unnecessary. That will save more money although I would use the Mundorf silver so you won't save much. The 2uf output caps are critical. I would go with Russian KBG 2uF 200V. That's what I use in the same position on my preamp and in my speaker crossovers.
Old 16th December 2011, 10:25 PM   #5
@palustris,
When you want have a good impact, I thought the most important cap is input cap which 1uf (C1a/b) in this case not the out put cap (C5a/b)
am I wrong? sorry I am still newbee here
Old 16th December 2011, 11:24 PM   #6
Alastair E's Avatar
The Best Cap......
Is NO Cap!
IF you can omit or redesign to remove a cap, while keeping things more or less the same, then you'll be better off than spending silly money on Daft AudioFool Craps!
Das Beste Oder Nichts
Old 17th December 2011, 05:44 AM   #7
cogsncogs's Avatar
The 470n + 10n caps are "inside" the feedback loop and as such will have an effect on low frequency stability. There is a subsonic peak on the first anode(s). Lowering the value of the coupling cap will raise that subsonic frequency and it's barely stable as is. I did a simulation of the circuit and according to the phase measurements, it will more than likely motorboat around 0.2Hz if the cap is lowered to 100nf.
Old 17th December 2011, 09:44 AM   #8
TonyTecson's Avatar
the circuit is complicated as i see it.....better sounds comes from simpler designs....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 17th December 2011, 11:35 AM   #9
Btw, cogsncogs,
you're a fan of Gentle Giant, aren't you?
Old 17th December 2011, 03:03 PM   #10
Mundorf Silver Oil slightly emphasizes the high notes.
Jantzen and Auricap tends to have warmer sound.
You can decide which one suits you.
All caps above definitely noticeable in different.
Something must be very wrong if one cant hear the different.
Thanks.
Help Pls - Coupling Capacitor tony Ma Analog Line Level 4 1st October 2013 11:37 AM
Coupling capacitor selection DcibeL Chip Amps 23 18th July 2011 04:20 AM
Capacitor coupling question... rtate Solid State 9 2nd August 2009 08:28 PM
coupling capacitor value reading ccschua Parts 3 31st May 2009 01:51 PM
Pls Help... Capacitor Mounting JojoD818 Solid State 3 2nd April 2003 07:10 PM
Copyright 1999-2017 diyAudio
