Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th December 2011, 02:29 PM   #11
PreCD's Avatar
Originally Posted by AndrewT View Post
listen to and measure the his when the input of the amplifier is shorted.
Now subtitute an 1k0 for that short and listen and measure hiss again.
Now go though your various sources connecting one at a time and one channel at a time and listen and measure the hiss.
Are any of your source noisier than the 1k0 resistor?
Andrew:
Thank you for the trouble shooting procedures. Headed out to breakfast but will complete this when I get back in.....
Old 18th December 2011, 02:40 PM   #12
PreCD's Avatar
Andrew:
Ok. The family has not yet arisen for breakfast so I had the chance to short the input leads of the power amp. Quite as a mouse. Quieter even. I am poking around for the 1k resistor.
Old 18th December 2011, 02:46 PM   #13
It should be just as quiet (measured).
When you exceed ~10k then you will measure and may hear more noise.
By the time you get to 100k you should clearly hear more noise.
But, I am suggesting 1k0 as a starter just to check that the power amp stays quiet when connected to a typical Rs.
regards Andrew T.
Old 18th December 2011, 10:53 PM   #14
So long as the old Wima capacitors are not damaged and out of spec, they will not be causing the hiss. The best way to spoil "box" capacitors is to fit the wrong size for the pcb and bend the leads too close the case, cracking the seals
Old 19th December 2011, 03:29 PM   #15
PreCD's Avatar
Thanks for the input. Yes I agree about trying to bend the leads on the box caps.
Still trying to find the time to experiment with the input leads as Andrew suggested.
Old 31st January 2012, 12:41 AM   #16
PreCD's Avatar
Andrew:
It has been awhile since we spoke about this issue and you were very kind to give me advice about using shorting plugs. I found the time to craft a pair, plugged into the inputs of my power amp, and all was quiet using a 1K resistor.
I did as you suggested and started down the line of my Adcom GFP-565 preamp inputs with the shorter plugs. None of the inputs I shorted made a difference in the hiss. As far as I could tell the level of hiss stayed consistent with the ear, not measured.
Again the hiss is not audible from a distance of a foot, maybe two if the house is dead quiet. That will give you an idea of the amount I am hearing.
Old 31st January 2012, 09:23 AM   #17
That leads me to make two tentative conclusions.
1.) the system gain may be too high for the music Source you have.
2.) the pre-amp is a bit too noisy for the following equipment.
regards Andrew T.
Old 31st January 2012, 10:42 AM   #18
PreCD's Avatar
I will make this last comment and leave this alone since I posted it in the parts section. I believe the preamp is just a bit noisy. I have it connected to an Adcom amplifier and these should pair well together.
Thanks Andrew for the shorter plug lesson. Slowly but surely my knowledge is building thanks to people like you.
Electrolytic Cap can I replace with film patfont Solid State 16 13th September 2011 11:19 PM
My RH84 Build - first amp after a 25 year break -:) prelius Tubes / Valves 4 9th June 2011 01:58 AM
FS : Wima 1.0uF 63V Metalized Cap for CD Mod xtaltech Swap Meet 28 3rd August 2008 03:11 PM
Seeking source for metalized film I_Forgot Planars & Exotics 7 15th April 2005 05:04 PM
How do I replace this 40+ year old selenium rectifier? darren01 Tubes / Valves 21 23rd June 2004 12:11 AM
Page generated in 0.11340 seconds (77.25% PHP - 22.75% MySQL) with 10 queries
