Russian FT-3 Caps - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th January 2012, 10:31 PM   #21
DIM is offline DIM  Russian Federation
DIM's Avatar
FT-3 no bad capacitors, but they no have direction on case. You must listen each for choice. Do not remove aluminum case, it's not make it better)
K-72 more better teflon capacitors, made for military and nuclear plants.
Old 10th January 2012, 12:29 AM   #22
drjb is offline drjb  Canada
Ok, Dim, thanks. I may give them a try.
Old 10th January 2012, 01:48 PM   #23
DIM's Avatar
Hope it help.
Try to find K72-П6, 0,1 - 2,2 uF. Excellent capacitors.
Old 10th January 2012, 05:34 PM   #24
Yes, it helped; thanks!
Do you mean K72-P6? Yes, I found some, but wondered why there were less money than the FT-3's?
Old 10th January 2012, 05:53 PM   #25
DIM's Avatar
In Russia the price of K72 above, you can find datasheets and compare for yourself. Ft capacitors for "vintage lovers")))
I'm using 2.2 uF 250V K72, like bypass in my tube amps and very satisfied.
Old 10th January 2012, 06:23 PM   #26
Ok, thanks. I'll have to try a pair.
Old 14th January 2012, 03:06 AM   #27
data is offline data  Australia
Does the K72 come in higher voltages?
Like 600v?
Old 14th January 2012, 12:44 PM   #28
Never mind, searched ebay and recognize the K72 caps.
Russian PIO caps. Should I use them? G Parts 118 23rd October 2016 09:02 AM
Russian FT-3 capacitors outer foil? merlin el mago Parts 5 13th July 2011 07:49 PM
WTB - Russian FT-1/FT-3 capacitors ThuyTN Swap Meet 1 1st September 2010 05:06 PM
Russian oil caps ? Tomatito Parts 38 20th July 2003 12:57 AM
Russian Military Caps. tone Swap Meet 2 21st February 2003 04:47 PM
Copyright 1999-2017 diyAudio
