Go Back   Home > Forums > Design & Build > Parts
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 13th September 2003, 07:58 AM   #1
moi is offline moi
Question 24v to 12v converter
hi
does anyone here can help me?
i'm looking for a 24v to 12 v converter for use in my fj42 hat is 2*12 v batteries
i want to use a cd player in it
so i just want to transform the 24v of the car in 12 volts for the cd player
(can't connect it on just one battery because of the alternator)
bye and thanx
Old 13th September 2003, 02:37 PM   #2
bawang is offline bawang
If your power/current requirements are low (ie around 2 to 3 Amps, I guess the easiest solution would be a linear regulator with an external pass transistor (such as 7812 with a suitably rated pass transistor). Have done it for my dad's BJ60. Only problem is when you need higher current for the power amps....... You'll need a switching regulator....
The other 'partial' solution is to just tap the power from ONE battery (the battery whose negative is the vehicle ground) and swap the batteries round every couple of days to ensure even charging.
The absolute solution would be to install a third battery (with its own charging alternator) and power your system from this battery. Keep all wiring and sound system grounds (including the chassis of the CD player, amps etc) TOTALLY separated from the existing electrical system.
Hope this helps.....
Old 13th September 2003, 02:56 PM   #3
moi is offline moi
thanks
i've found a 6a converter for only 20 dollars
cool
bye
Old 13th September 2003, 04:23 PM   #4
JOE DIRT®'s Avatar
bye
Member of WATT
STAY LOOSE
Old 14th September 2003, 08:31 AM   #5
Hmmm..... US$20 for a 6A, 24V DC to 12V DC converter? A bargain, if it really can deliver the full, continuous 6A!
Let's see, at 6A current and a 12V drop across the external pass transistor(s) for a linear supply, you have a theoretical dissipation of about 72W at the pass transistor, which is very significant and needs a large heatsink. Unless of course, the converter unit is a switching converter.......
Kind of reminds me of the 1,000W PMPO ghetto blasters....
Anyway, good luck and enjoy....
Old 15th September 2003, 01:47 PM   #6
moi is offline moi
i'll post a reply when i receive it (3 weeks)
conrad.com
bye and thanx
Thread Tools
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 05:09 PM
24 bit 356 kHz DA converter martioz Digital Source 10 13th December 2004 09:01 AM
NEED DC to DC Converter sma Car Audio 3 16th December 2003 07:24 AM
Page generated in 0.25519991 seconds (69.77% PHP - 30.23% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
