Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Silver Mica caps VS Polystyrene caps
Old 14th August 2013, 04:20 PM   #31
DF96 is offline DF96  England
Silver mica caps are usually very stable, but I'm sure I read somewhere that they can sometimes have sudden (but small) changes in capacitance. Not likely to affect audio, but could be a problem for their usual use in radio circuits.
I once had problems with some new SM caps causing crackles and pops when used for frequency compensation across an anode resistor, even though the voltage was well within their rating.
Old 8th October 2013, 03:29 AM   #32
MITsound is offline MITsound  Canada
MITsound's Avatar
Made some really simple line level bass filters to go between DAC and integrated amp. Dialled in value (1500 pf ) with some cheap trimmer caps, and just sent for some nos soviet military SM caps. Think this was a mistake? Ought I instead use
Polystyrene or Pio ? Tried teflon F&F in other applications, didn't care for sound in my system. Ex soviet military teflon is inexpensive if that's your recommendation though. Regards, Mitchell.
Old 8th October 2013, 10:07 AM   #33
I have never used teflon caps. I would always avoid paper in oil because paper caps eventually absorb moisture and that increases capacitance and leakage. PIO was all they had before plastic dielectrics were invented; we don't have to copy them.
Old 8th October 2013, 08:26 PM   #34
ticktock is offline ticktock  Scotland
ticktock's Avatar
Originally Posted by clarkynoel View Post
so the conclusion is better silver mica than polystrene like Wima MKP or FKP?
In real life it's a matter of cost and physical size.
I use micas where low capacitance values are required, then polystyrene and poly
film/foils, then metallized polyprops, then mylar, then lytics, where I need big values.
thanks
Blaue Leuchtdioden machen blöd. (hb)
sent from NSA monitored device
Old 8th October 2013, 10:58 PM   #35
MITsound's Avatar
Thanks all. Will try SM caps first then.
Old 9th October 2013, 08:14 AM   #36
gmphadte is offline gmphadte  India
Where will you use them. In audio!!!
Gajanan Phadte
Old 21st July 2015, 03:34 PM   #37
lucpes is offline lucpes  Romania
Send a message via Yahoo to lucpes
Thumbs up for silvered mica in values as high as you can get for vrail bypass!
We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines. Measurements can provide a measure of insight, but are no substitute for human judgment. Nelson Pass
Old 22nd July 2015, 11:50 AM   #38
marce is offline marce  United Kingdom
What vrail bypass and where in the circuit?
Old 11th November 2015, 01:14 PM   #39
RhythMick is offline RhythMick  United Kingdom
Originally Posted by haldor View Post
Might also have something to do with the fact that silver mica caps with larger than 1 nF are just about impossible to find. That would tend to limit their use in audio.
Phil
HiFi Collective have Silver Mica up to 10000pF. I'm planning to use them in RIAA.
Technical specifications:
Dead Dimensions: 0.6mm dia x 60mm length
Capacitance Values: 1pF - 10000pF
Voltage Values: 500Vdc
Temperature range: -55 to +150C degrees
Capacitance Tolerance: +/- 5%
Silver Mica | Hifi Collective
Old 11th November 2015, 02:14 PM   #40
cliffforrest is offline cliffforrest  United Kingdom
That should be Lead Dimensions, of course! And plated steel leads which should scare off those of a nervous disposition.
5% is not great, 1% or 2% polystyrene are much more useful in filters.
Silver Mica caps VS Polystyrene capsHide this!Advertise here!
silver mica caps doktor Parts 14 26th April 2006 02:08 AM
silver mica and pp caps ronardi Parts 3 24th March 2005 03:06 PM
silver mica caps code tubbytwo Parts 2 2nd December 2004 12:58 AM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 02:02 PM
