| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Just an update on my component sourcing, i thought you guys might be interested in:
After spending much time searching for my bits, i wanted to recommend 'small bear electronics' and 'futurlec', i found quite a few companies that stocked the obsolete parts that i needed but i would have had to have made minimum order of 75-100 which was way beyond what i needed, the companies above do 1's and 2's off if thats all you need, the postage came to more than my parts though. Oh yeah, when my LM3900 arrived, i was so excited, i went straight to my workshop and swapped out the LM324, i powered up the circuit and ........nothing!!! after scoping around for a few mins, i realised i had laid out my veroboard for the LM324 and they arn't pin for pin replacements.....DOH! Now i have to start again and lay it all out for the new device, i hope i havn't destroyed it! although i did buy 3 of them just in case. Neil. |
#2 |
Neil, thanks for the heads-up.
BTW The 3900 is a very different animal than the 324; are you aware of that? Apart from the pinout, you can not just swap the two in a circuit. For one, the 3900 has one input that is very low impedance and is meant as a current input, while the 324 is a 'real' opamp with two high impedance inputs. But there's more. jan didden
/Another new issue: Linear Audio Volume 3! |
#3 |
Thanks Janneman, i was only aware of this after i put the circuit together thinking at the time they were compatable lol
Neil. |
| Department of Ooops | SY | The Lounge | 7 | 30th December 2010 04:41 PM |
| Ooops, I bought AC voltmeters and needed DC | trondareo | Everything Else | 6 | 10th May 2010 11:15 PM |
| Ooops! Bought a three phase bridge by accident. | seabass23 | Solid State | 1 | 13th March 2010 05:08 PM |
| symmetrical 400 buzz ...ooops ...help! | Mattyo5 | Solid State | 21 | 28th October 2003 12:23 PM |
| Page generated in 0.06642 seconds (67.09% PHP - 32.91% MySQL) with 10 queries |
