Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th November 2011, 02:02 AM   #1
audiobilly's Avatar
Default Axial Electrolytic Recommendations
Greetings To All,
I have an compex limiter that I am trying to find replacement axial electrolytic capacitors for. I want to re-cap the audio path. After much searching, it seems that high quality axial caps are just not around. Lots of radial choices, bot no axial. Can anyone shed some light or have any recommendations they can share?
Thanks for your time!
Old 30th November 2011, 02:17 AM   #2
lms is offline lms  Micronesia
Default axial
what capacitys and voltages do you need?
Old 30th November 2011, 02:26 AM   #3
Joachim Gerhard's Avatar
This ones are good :
http://www.vishay.com/docs/28334/118aht.pdf
Old 30th November 2011, 03:20 AM   #4
audiobilly's Avatar
Thank you for the response lms,
This is for small signal coupling and de-coupling, for approx -10dbm level signals.
220uf@25v, 100uf @25v, 47uf@25v, 22uf@25v, 15uf@40v, these types.
Old 30th November 2011, 03:21 AM   #5
audiobilly's Avatar
Originally Posted by Joachim Gerhard View Post
Thank You Joachim, I will look into these. Finding vendors that have stock will be the next hurdle. One problem at a time!
Old 30th November 2011, 03:39 AM   #6
Farnell, RS
Old 30th November 2011, 07:58 AM   #7
AmpliFire's Avatar
Digikey as well
Old 30th November 2011, 08:13 AM   #8
mjf is offline mjf  Austria
i used vishay 021asm in my dynaco pat4.
(the datasheet is by philips,but now it is vishay!)
Old 30th November 2011, 12:31 PM   #9
Enzo is offline Enzo  United States
And a quick look at Mouser for axials in stock:
25v caps
100uf - 19 choices
220uf - 8 choices
47uf - 6 choices
22uf - 5 choices
and 15uf/40v? No, but at 50v there are 4 choices
Brands include Vishay, Nichicon, Xicon.
Old 30th November 2011, 02:24 PM   #10
audiobilly's Avatar
Thank you all very much for your input. It is greatly appreciated!
When one talks of high end capacitors, Black Gate, Elna SILMIC, Nichicon MUSE, none of these are available in axial variety. I can find axial caps via Mouser, Digi-Key etc, etc. BUT, is there any high end axial caps out there comparable to the Black Gates, Elna, Nichicon?
I have not considered the Vishay, mmm. Will be looking into these guys.
Thanks again everybody! All input is good stuff!
Beyma co-axial drivers dudaindc Swap Meet 5 11th August 2010 09:46 PM
Crossover co-axial jjman Tubes / Valves 0 17th June 2010 12:31 AM
Fostex co-axial 8 inch? mctavish Full Range 2 31st December 2009 02:29 AM
axial caps becoming extinct? Clipped Parts 4 31st August 2006 12:25 PM
Pseudo co-axial? Nuuk Multi-Way 15 21st December 2005 11:27 AM
Page generated in 0.09127 seconds (80.03% PHP - 19.97% MySQL) with 11 queries
