Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
140V on a 18V transformer's secondary!!!???
Old 10th September 2003, 07:14 PM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default 140V on a 18V transformer's secondary!!!???
I assembled my gainclone in it's new case today, and before connecting the whole thing, I tested the diode bridge (without load)
On the scope, between the + and - of the positive bridge, I got a sine wave, 140V p-p !!!! And 50Hz instead of 100. And the signal is a sine, instead of a rectified sine
I attached a picture of the diode bridge. I measured between the left and the center point.
I don't even know where can 140V come from! It's a 2x18V trafo, so 25V p-p
help!
Old 10th September 2003, 07:37 PM   #2
till is offline till
Banned
No load? you measured with a voltmeter with high resistance? You measured something capacitively coupled to the mains?
Old 10th September 2003, 07:40 PM   #3
Bricolo's Avatar
No load, only the trafo connected to the diode bridge (and they are only 100V diodes!, can they be hurt?)
I measured with the scope
Old 10th September 2003, 07:41 PM   #4
Bricolo's Avatar
one thing: the point connecting the 2 bridges (the 0 point) isn't grounded or earthed yet. Can this change something?
Old 10th September 2003, 08:08 PM   #5
Banned
Didnīt you ground it to the scopes ground?
Old 10th September 2003, 08:12 PM   #6
Bricolo's Avatar
yes I did, so this isn't the problem
I can't imagine how I can have 140V!!!
Old 10th September 2003, 08:14 PM   #7
Banned
please measure with a load, even a small one, a LED and some k or so, that ensures ther IS really a little current flowing.
Old 10th September 2003, 08:40 PM   #8
Bricolo's Avatar
I tried, without hoping any good result
I added a 9.5K resistor between 0 and +, and the same for the - side.
Now I have a clean full wave rectified sinusoid, 100Hz, 25.2V
It works OK now, thanks Till
But I'm very affraid of the results I first got
140V p-p, 50Hz sinusoid (not rectified), but the secondaries were clean 50Vp-p (18V RMS) sinusoids
I only have 100V shottky diodes, I wonder if they could have been damaged.
Imagine if I had the caps connected my 50V caps would have exploded
I'm seriously thinking about keeping those 9.5k resistors on the diode bridge, to always have a load.
the strangest thing is that the voltage across each diode was much higher that the secondary, but each diode didn't have the same voltage graph (on the scope). each one was veeery different from the other
Old 10th September 2003, 08:49 PM   #9
Banned
my 100V schottkys have no prob with a 87V power supply in my BZLS. Dont you think the caps are resistive enough? or do you use only filmcaps and no electrolytics?
Old 10th September 2003, 08:57 PM   #10
Bricolo's Avatar
Nice, I use the same diodes as you
The caps could have been a high enough load, too.
But I take care of my panasonic FCs, expensive stuff compared to what I usually use
140V on a 18V transformer's secondary!!!???Hide this!Advertise here!
transformer secondary connections jayme Tubes / Valves 0 4th October 2007 07:31 PM
help with transformer secondary jarthel Power Supplies 34 8th July 2006 01:01 AM
Secondary of a transformer as a choke? Andypairo Pass Labs 2 27th October 2002 09:50 AM
