| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am building a three channel guitar amp, and am having trouble selecting
a good signal relay. I will be using three SPST (preferable 5v) and two DPDT (16v) relays. Any advice? |
#2 |
Sounds like you want relays that are powered/switched by 5 volts. We need to know how much voltage and current you are going to switch. For a good overview of relay types check out this page. http://www.surplussales.com/Relays/sealed_pc.html
"You can keep your insurance baby nothing is guaranteed" -Tom Petty Last edited by firechief; 17th November 2011 at 04:30 PM. |
#3 |
I am quite happy with these ones:
http://search.digikey.com/ca/en/prod...Z133-ND/307653 They are available in various coil voltage ratings. Last edited by discrete; 17th November 2011 at 05:10 PM. |
#4 |
The SPST are comming of the guitar input jack.
The DPDT will never see more than 800mv |
#5 | |
#6 |
I used these 5v relays for chanell switching in my latest 2 channel guitar amp ...
Welcome to Sanyou |
#7 | |
#8 |
At work we mostly use Axicom, Omron and Zettler (and some others). Only Omron has given us some quality issues over the years (actually enough for a customer to do a redesign).
For your application I'd recommend you check out the Axicom V23105 series, but any good quality relay should be suitable. |
#9 | |
On another subject, I need to find a toggle switch that won't pop when switching. I wire a mid pot bypass that works well except for the pop. |
#10 |
I have a lot of relays in stock
SPDT OMRON G5V-1 5V .99ea SPDT OMRON G5V-1 12V .99ea DPDT OMRON G5V-2 12V $1.50ea DPDT OMRON G6A-234P-ST-US 5V $1.50ea As for toggles I have them too but they do click. Steve @ Apex Jr. |
| WTB: Audio Signal Relay | gabanyayaya | Swap Meet | 1 | 10th April 2011 01:01 PM |
| Signal relay. | Ted205 | Chip Amps | 5 | 18th November 2008 07:47 AM |
| Using latching signal relay in SE guitar amp. | G | Tubes / Valves | 3 | 22nd March 2005 12:08 PM |
| Creating a differential signal from a single-ended signal for bridged amps | Peter Daniel | Chip Amps | 45 | 8th November 2004 12:47 PM |
| Relay recomendation for signal switching | simonk | Solid State | 1 | 18th January 2002 05:34 PM |
| Page generated in 0.09661 seconds (79.09% PHP - 20.91% MySQL) with 10 queries |
