| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Does anyone know of some nice looking RPGs or RPG knobs? I am using an RPG in a project for digital volume control. All the RPGs I have seen have very small knobs. Any suggestion for something that is a typical volume-sized knob?
Thanks! |
#2 |
Pardon my ignorance, is the RPG an encoder? There are both relative and absolute encoders, I would assume this to be an absolute. The encoders I work with - data wheels for control panels mainly - have shafts that will take knobs. And chose the knob you like there.
#3 |
Yes, it is an encoder. It looks like RPG isn't common terminology outside of my old job. I would be looking for a relative encoder. Do you know of a vendor that sells nice looking knobs?
#4 |
WHen I see RPG, my first thought is rocket propelled grenade, then my second thought is role playing game.
Unless I screwed up the terms, relative would be the ones that have no set direction indicated. Like a lot of data wheels, you turn it and from wherever it was before it goes up or down. The absolute position is like a regular pot, the absolute position is indicated in the code. Many sources of knobs, even Mouser, Jameco and such places. Certainly the surplus outlets. I contacted ROgan (a knob maker) once and got a free bag full of various knobs as samples. I work in pro audio, so I always have lots of knobs to fit various shafts on the controls of guitar amps, mixers, and other gear. If you see something on a product in the industry, you could obtain from them. Not knowing what you have, check the following when shopping. Shaft diameter - 1/4", 1/8", 6mm, etc. Shaft type - solid round shaft, D-shaft (And note the flat on the D can face different directions), knurled shaft, split knurled shaft. ANchor type - set screw? Push-on? Collet? MAterial - metal, plastic, wood Cosmetics - shape, color, rubber or hard, pointer or no, skirt or no, etc. |
#5 |
small knobs----Just do some add-on thingies and make it big.
Gajanan Phadte |
| WTB: small 4 position rotary switch | jean-paul | Swap Meet | 1 | 9th January 2011 01:46 PM |
| Rotary Knobs | kingsteven | Parts | 1 | 14th October 2007 08:22 PM |
| ITT 30 position rotary switch | WALTER BURKHARD | Swap Meet | 3 | 21st December 2004 12:22 AM |
| 3-pole 4-position Elma Rotary Switch | s0rce | Swap Meet | 0 | 19th January 2003 02:14 PM |
| Grayhill 7pole 20 position rotary | Bill Fitzpatrick | Swap Meet | 15 | 19th November 2002 01:15 PM |
| Page generated in 0.08928 seconds (76.85% PHP - 23.15% MySQL) with 10 queries |
