Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Transformer with two secondaries and multiple taps - how to parallel?
Old 1st November 2011, 01:54 PM   #1
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
Default Transformer with two secondaries and multiple taps - how to parallel?
I have a couple of Ultron Universaltrafo E 12 180 VA transformers. They are E-I type transformers with dual secondary windings, and the secondary windings have multiple taps:
primary: (0-220)
secondary1: (0-20-24-30)
secondary2: (0-20-24-30)
What I want: Secondaries in parallel, 20V output. With increased current capability obviously.
How do I do this? Simply connect the two 0V-taps together, and also the two 20V-taps together? And leaving all the other taps floating?
I can post pictures or provide drawings in case my description is not clear enough...
Gravity - Making the G since 13.7 billion B.C.
Old 1st November 2011, 01:56 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
nope
let each sec ( 0-20) have his own Graetz
then connect two Graetz outputs in parallel
that way they're isolated with bridges
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 1st November 2011, 01:57 PM   #3
mace1337 is offline mace1337  Netherlands
Yep, you can definitely do that.
e: But Zen Mod's suggestion is better.
Old 1st November 2011, 02:13 PM   #4
hates ground loops
Rodeodave's Avatar
Yeah, well, here's the thing: As it is now I'm using the transformer for a bipolar supply, each secondary winding hast its own Grätz, thus producing +/-28V DC. Since the transformer gets fairly hot, I want to feed each Grätz with its own transformer (= using one transformer per polarity).
That's why I need parallel secondaries.
Old 1st November 2011, 03:20 PM   #5
jitter is offline jitter  Netherlands
jitter's Avatar
Even though, they're rated the same, the secondaries are never exactly 100% identical due to tolerances. Currents will flow between them resulting in a transformer that will heat up more than necessary.
Rectify first, like Zen Mod suggested.
Transformer with two secondaries and multiple taps - how to parallel?Hide this!Advertise here!
Dynaco 440 Transformer Cathode/Screen Taps 6P1P 6AQ5 UL transformer TheGimp Tubes / Valves 14 30th October 2011 12:20 AM
SimpleSE amp: multiple taps with cathode feedback mluckow Tubes / Valves 27 1st December 2008 07:12 AM
One transformer with 4 secondaries or two transformers with dual secondaries Baka Chip Amps 5 28th November 2008 06:39 AM
Multiple secondaries hook-up!!! Klimon Tubes / Valves 4 10th July 2006 02:32 PM
multiple secondaries on a toroid awashi Power Supplies 12 10th July 2005 06:26 AM
Copyright ©1999-2017 diyAudio
