| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
How do you connect multiple power amp modules to the PS rails in a way that allows them to be easily connected and disconnected (I may not always be using all channels?
I've googled terminal strips, distribution strips, and bus strips, and bus bars and come up dry. The ones I've found connect two wires to each other, or at most four. I'm going to assemble an 8 ch amp, and I'd like to avoid clutzy daisy-chaining.
----------------------------------------- Noah |
#2 |
Make your own with copper strips and fix lugs for ease of disconnecting.
Gajanan Phadte |
#3 |
Have you priced copper lately?
It has to be thick so the threads won't strip, drilled, tapped, mounted on something, etc - couple of hours as slow as I am. I found these, expensive but fast and pretty like a Ferrari vtewarehouse.com/content/electromech/busbar/html/10point/10point.php
| Replacement amp for A-Bus? | Greg911 | Class D | 0 | 16th November 2008 02:33 PM |
| UcD modules - can the modules work without the input op-amp? | beppe61 | Class D | 8 | 11th October 2006 07:35 AM |
| i2s bus vs. i2c bus | Doovieman | Digital Source | 8 | 13th October 2005 07:06 PM |
| Strip a UPS to use as an amp PS? | DonoMan | Parts | 6 | 16th February 2005 06:34 AM |
| Influence of PS on clock modules | fmak | Digital Source | 49 | 22nd April 2004 01:42 AM |
| Page generated in 0.07289 seconds (72.20% PHP - 27.80% MySQL) with 10 queries |
