Wanted: PCM1760U ADC - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th October 2011, 02:59 PM   #1
Default Wanted: PCM1760U ADC
I have a digital mixing console getting white noise on most channels. It uses 10 PCM1760U ADCs each having two channels. I have found them for $40 but I have to buy 20 or I can buy them for $60 each. Either way the repair would cost more than the console is worth.
Any ideas of an alternative ADC or a better price?
Old 29th October 2011, 04:01 PM   #2
Enzo is offline Enzo  United States
How did you determine it was the ADCs instead of the analog sections before them?
Old 29th October 2011, 04:27 PM   #3
theAnonymous1's Avatar
Get a quote from this site.....
PCM1760U datasheet pdf,PCM1760U supplier,PCM1760U price,PCM1760U picture at UTSOURCE
I've bought from them a few times so I know they are legit.
I put in a quote with a local dealer for you to see what they want for 10pcs. There's also a seller on e*ay that has them for $19.99 + postage.
Old 30th October 2011, 06:03 PM   #4
Although it is likely that PCM1760U are bad (assumed). This is the circuit between preamps and ADC. Is a likely source of noise obvious? The noise is not in pairs as I would have guessed if ADC was bad but Yamaha dealer seems certain that ADC are bad.
Noisy ADC 5th element Digital Line Level 6 30th August 2009 11:29 PM
ADC in 18f4550 piyushgupta.iit Digital Source 11 11th July 2008 10:50 PM
ADC Equalizer GEirin Solid State 3 20th February 2008 03:22 PM
ADC specs percy Digital Source 10 12th January 2008 03:18 PM
Wanted to buy: Datel ADC-HX12BGC audio1nut Swap Meet 0 23rd August 2004 04:52 AM
Copyright 1999-2017 diyAudio
