| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Would there be any benfit to replacing an older 555 timer chip with a more modern unit?
This unit in question is in a mid seventies reciever, and I believe is part of the tuner section. (At the very least, I can't imagine what it would do for the pre or power amp section )
#2 |
I can't imagine what it does in the tuner either...
I would say no, leave it be. Reason why, it may be used as a pulse generator/monostable etc and replacing with a low power version would alter it's characteristics slightly maybe needed a realignment of something else. You need to know what it does ? I have never come across commercial kit that used a 555 tbh. Could it be used as a negative rail generator (charge pump) ?
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
It's not hugely important, really. This is an old, low-power reciever (Lafayette Lr310)I've had my eye on to refresh once I got the money to do so. The goal here would be to improve performance.
Thanks for the answer though. I never realized that there were so many different variations of this chip. The one in question is a metal can type, something I've never seen done with an IC. "C555a 2" |
#4 |
It is most likely not a timer IC! It is an rf IF IC also called a 703 originally by Fairchild!
#5 |
Never mind, replacing it with a plain 555 might have interesting results, like converting an old analogue tuner into a top class DAB receiver. You never know.
#6 |
I'm willing to believe Simon, but if we have to have a 555 timer IC, I could see it as a delay for a speaker relay or similar application. Or as a blinker for some indicator light.
#7 |
Well well, this has turned out to be an interesting discussion.
I took another look at it, and it is on the edge of the tuner, where it ends and the amp begins (they're on the same board). I opened up my little tiny Integrated amp, which is also a Lafayette, and it does not have one of these. The little metal can chip in question was made by NEC, and the reciever itself was made between 74 and 78. |
#8 |
The original NE555 timer was Signetics, not Fairchild. I don't remember a TO5 like can version. I remember P & D(ceramic) dips. I do have an original Signetics catalog but can't reach it.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500 |
#9 |
Supply on pin 8 and ground on pin 1 would go some way to identifying it for sure.
There are only a few configurations the 555 is used in normally so easy to tell from the parts around it. Close up pic of the chip and surrounding area maybe...
#10 |
It's quite strange that there's a NE555 in a receiver. Maybe it's configured as a trigger, or flip-flop, controlling buttons :-P
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services Chat with me |
| Class D amplifier using a 555 timer | dano12 | Class D | 0 | 12th December 2010 03:32 PM |
| 555 Timer Triggering Problem | silentblackhat | Digital Line Level | 1 | 11th February 2009 06:32 AM |
| 555 Timer Trigger Input? | silentblackhat | Solid State | 3 | 8th February 2009 07:22 PM |
| 555 timer latching | nickch | Parts | 1 | 20th July 2005 08:48 AM |
| Question about 555 timer circuit with relays | Ralph | Parts | 27 | 9th October 2004 11:53 AM |
| Page generated in 0.09346 seconds (81.01% PHP - 18.99% MySQL) with 11 queries |
