Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th October 2011, 09:25 PM   #1
Default Elementary tarnsformer question...
Hi there -
Basic question about mic input transformers... thanks for your patience.
I'm considering the Cinemag CMMI-10C (based on a recommendation): http://cinemag.biz/mic_input/CMMI-10C.pdf
I'll have a switch for the primary tap to allow low or normal input impedance.
What I'm confused about is that the transformer has 1:20 or 1:10 windings ratio, but I don't understand how this is accessed: the schematics in that PDF show the tap for low input impedance, but the secondary looks like a normal two-lead secondary... are they just not showing another set of wires in the schematic? I think I may be misunderstanding something fundamental about this...
Thanks for any ideas!
-Casey
Old 27th October 2011, 10:08 PM   #2
The primary has a centertap.
With the 1:10 ratio the whole primary is used.
With 1:20 the input is connected to the centertap.
Not the most elegant solution, as the 1:20 connection only uses halve the primary a
Old 27th October 2011, 10:12 PM   #3
and leaves the other halve there for nothing.
It had been better when the two primary halves could be parallelled for 1:20; this improves coupling and lowers DC resistance, but an extra termination is required therefore.
Old 27th October 2011, 10:14 PM   #4
benb is offline benb  United States
Well, yeah - it looks pretty simple to me. The input side is center tapped. When using the whole input winding with BRN/5 and ORN/2 for the input, as shown in test circuit #1, the ratio is 1:10. When using half the winding by using the center tap, as in the ORG/2 and RED/3 wires in test circuit #2, you're only using half the primary winding, which makes the ratio 0.5:10, or as it's normally given, 1:20.
Old 27th October 2011, 10:17 PM   #5
Thanks pieter t...
Ok, so the input impedance is dependent to the step-up/turns ratio... they are not two independently selectable things.
Why then does the CMMI-7C: http://cinemag.biz/mic_input/CMMI-7C.pdf
...have basically the same schematic (though there is no connection dot for the primary center tap connection, i assume that's irrelevant?) but only one listed ratio of 1:7, instead of "1:7 and 1:14" or something? Just inconsistencies in the descriptions?
Maybe I shouldn't be learning electronics from brochures. :-)
Thanks a lot!
-Casey
Old 27th October 2011, 10:19 PM   #6
Thanks benb as well - just saw your post. Yeah, I think I was just confused by inconsistent presentation in the various PDFs.
Old 27th October 2011, 10:32 PM   #7
Yeah, it suggests that this one can be connected 1:14, so I guess "inconsistencies in the descriptions".
Elementary Amp Building Questions joekraska Class D 10 31st December 2009 04:59 AM
Some elementary questions about dumb-simple MC stage design Axon Solid State 1 15th March 2009 02:13 PM
Really elementary question about caps. G Tubes / Valves 4 7th March 2007 02:24 PM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Page generated in 0.08145 seconds (78.10% PHP - 21.90% MySQL) with 10 queries
