| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have been making some of my own audio cables for a little bit now and i just have a couple questions. I have been using some gepco cable with 2 lines and a drain wire. I solder the red lead to the pin, and I solder the drain to the ground of the RCA connector. On the source end, I solder the black end with the drain on the ground (to eliminate ground loops).
Is this suitable for subwoofer cables as well? Will this work for video cables? Or do I need to look into coax cables? |
#2 |
video usually uses coax or something more exotic. I get video RCA cables for $1 at the resale shop and use them for audio some. Huge surplus since the VCR scrapout.
Subwoofers need fat wires more than any wire layout. No RF (radio frequency) implications of sub-woofers. Look at he alphawire.com tables for wire carrying capacity, then figure the amps of your subwoofer by I=sqroot(P/R) where p is power and r is nominal impedance of your subwoofer. I is current like in the tables. Fatter wire than the limit gets better control of the speaker by the amp. (damping factor).
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500 |
#3 |
Is it a powered sub or not?
#4 |
Did it Himself
That method of cable construction won't do anything for ground loops, which are caused by a different mechanism.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
| Driver stage to finals newbie questions - (I hope not dumb questions) | rongon | Tubes / Valves | 15 | 13th June 2011 08:29 PM |
| Old power cables make good audio cables? | paean | Parts | 9 | 2nd November 2010 08:21 AM |
| Some Quad els57 questions! - Novice Questions! | Fanuc | Planars & Exotics | 13 | 5th December 2007 09:26 AM |
| ssabripo's DIY Interconnect cables: $200 cables for 1/10 th the cost! | ssabripo | Everything Else | 3 | 26th October 2006 02:33 PM |
| cables for diy amps, preamps, and speaker cables ... | paulspencer | Solid State | 5 | 3rd August 2004 07:14 AM |
| Page generated in 0.06059 seconds (82.09% PHP - 17.91% MySQL) with 10 queries |
