Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th October 2011, 12:10 AM   #1
beau2317's Avatar
Default How to make an awesome teflon coupling cap for very little.
This thread explains how to make a really great sounding coupling cap from the cheap Russian teflon caps you can buy on ebay for a few dollars.
The idea is to de-skin them and then make them solid enough to use. This is not an original idea - others have done this - but this thread explains exactly how to do it.
This is what they look like:
I have 0.1uF 600V examples here. That unfortunately is about as large as the values get. Maybe 0.22uF. But remember, teflon caps are bigger than normal caps.
The tools I used:
Start by using the tin snips to make small cuts around the ends of the cap:
Then use the pliers/mole grips to bend the tabs you just created back and forth 3 or 4 times to let metal fatigue do it's work.
Once you have gone all the way round both ends it looks like this:
This is where you need to be careful. Pull both ends gently. Usually one end will pop out to reveal a wire:
Cut this wire off. Now you can remove the cap from the can.
Unwrap the outer layer of teflon and cut the wire off the other end:
Tape round the caps. The tape I used was very conveniently a little wider than the caps.
Last step is to put epoxy resin in each end.
How they sound
For the last few weeks I've been trying out various caps in a tube output stage of a Buffalo III DAC
Some of the caps I tried:
-- Cardas "Golden Ratio"
-- Mundorf Gold/Silver
-- Mundorf Silver/Oil
-- Obbligato Premium
-- Clarity Caps
-- Jensen Copper foil/paper/oil
-- VTV Ultra Tone silver foil/paper/oil
None of them really was perfect. The closest was Mundorf Gold/Silver.
I thought I'd try the old Russian teflon (K72) caps I'd bought several years ago. I found that they have much more resolution than any of the other caps I'd tried. Easily. But they had a couple of serious shortcomings. Firstly they sounded like they were shouting somewhat (hard to explain). Secondly, the bass was a bit light.
If you tap the can of the russian caps they have a horrible pingy resonance. Also they are steel. I figured that neither of these are good, so I wondered if I could de-skin them.
It turned out to be easier than I thought.
And the sound is now amazing. The shouty-ness is completely gone, replaced by a smoothness. The bass is strong and punchy. I really can't fault them.
The four caps you see in production here are the second batch I made, and they went into my Moskido power amp, where they also sound great.
So, if you need a great cheap 0.1uF coupling cap, try these..
Moskido (Hybrid Aikido/Mosfet); Verumecce (biased interconnects). Buffalo III with Unbalancer tube output; Magnepan 3.6R
Old 17th October 2011, 02:23 AM   #2
Well I'll be b*ggered! I have quite a few of these and it never occurred to me to try them without the metal jackets/cases.
Curiously enough, I have just received some "naked" Auri caps (made by 'SiderealKaps') and they don't have either the Auri wire on the ends (now have solid copper + teflon sleeve) or the plastic end caps - apparently, the best 'ends' are either beeswax or the 'french polish' to seal the ends completely and "best sound".
Interesting - might try same "de-skinning" of the K73-16s to see what happens there too - another great "bang for the buck" capacitor.
Excellent photo instructions - thanks for going to the trouble to post this up - definitely an "add-on" to the Moskido thread.
... jh
Old 17th October 2011, 02:28 AM   #3
beau2317's Avatar
Hah beeswax. I was silly enough to buy some of those Jupiter Beeswax caps. Boy are those rubbish. Not only do they sound ordinary, I've had 2 out of 4 fail in spectacular fashion. (Also have had high-end Audio Note caps do the same).
I'm so fed up with the BS of the mainstream hifi industry invading the DIY space.
Old 17th October 2011, 03:53 AM   #4
Ah! Good to get that "outa-ya- system"!
I got a bit impatient with the cans and just peeled the outer case off like a sardine can and can clearly see how they built them - a lot of trouble - not a cheap cap at all - silver wire?
Despite your aversion to beeswax(!) will dump them in and add a coating with a heavier dollop on the ends, then tape them up as you did - maybe try to add an outer sleeve of thin rubber before taping to see if any microphonics remain - interesting.
What is the difference between these K72P-6 ones and the K72-11s - the 11s are available at eBay in the 0.22uF size but only 0.1uF in the -6s at present. Maybe Siberian Audio .....?
... jh
Old 17th October 2011, 04:00 AM   #5
beau2317's Avatar
jh - actually big problem with beeswax is that it melts at the temps you find in tube amps.
Did you look closely at the 0.22uF 11s? They are h-u-g-e. Length - 8 inches. Weight - 2.75 pounds!!
I've heard that the FT3 types are basically the same inside.
Old 17th October 2011, 04:05 AM   #6
If what you did improves the sound, you probably made it worse by potting the ends.
Old 17th October 2011, 04:13 AM   #7
Damn! I thought I was onto a good thing there - can't have melting caps "a-la" Jupiters - will have another think.
I seem to have same idea as "454" that the sealing ends are quite critical to the behaviour of the caps, so a bit of a project just started - interesting.
Incidently, have some Neotec silver wire coming for the battery biased interconnects - haven't forgotten them, just 'slack'!
... jh
Old 17th October 2011, 04:22 AM   #8
beau2317's Avatar
Really, what makes you say that?
Given that the potting materiel at the ends does not form part of the dielectric, I doubt it. Also it adds structural rigidity (along with the tape).
Oh, did I forget to mention that when I first tried the deskinned caps, I did NOT pot them, but there was no way I would actually use them like that long term - they are much too fragile. (I managed to break two out of eight caps I deskinned)
If anything, the potted version sounded better, but there's really not much between them.
If epoxy end caps are good enough for v-caps they are good enough for me.
So c'mon. What's the theory that says end caps make caps sound worse?
Old 17th October 2011, 04:45 AM   #9
My theory will embarrass both of us were it to be revealed. It'll remain secret for now.
Old 17th October 2011, 05:47 AM   #10
Calvin is offline Calvin  Germany
Calvin's Avatar
getting rid of a mechanically very stable metal casing and just taping the roll instead will leave a rather soft structure, much more prone to microphony. Putting some sludge on the ends of the roll won´t solve the major prob of such a thingie.
This will surely influence signal accuracy in a negative way. Some will probabely like the sound though, simply because its a piece of DIY.
jauu
Calvin
Polar electro with bypass cap to replace nonpolar as coupling cap? at77 Parts 0 12th January 2010 02:05 AM
auraTEFLON Vs V-Cap Teflon Capacitors TheMooN Parts 1 26th April 2008 12:34 PM
Now wouldn’t this make an awesome monoblock. GK Tubes / Valves 8 24th February 2007 02:59 PM
Coupling cap Raka Chip Amps 11 9th June 2003 01:06 PM
.22uf cap in place of .25uf coupling cap, OK? bbaker6212 Tubes / Valves 5 15th July 2002 09:08 PM
Page generated in 0.69217 seconds (15.80% PHP - 84.20% MySQL) with 10 queries
