Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
How many amps are necessary for trouble-shooting a tube set-up such as a fisher or sherwood amp? 10, 15, 20, more?
#2 |
with 10 or 20 amps you can arc weld...
Bigger is always better, but its generally more expensive too. A 500W variac should be ample, 350W would be ok. Less than that is likely a toy.
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile, |
#3 |
I use a 10A model and know a few other tube guys who do as well. No problems. Probably overkill.
#4 |
+1 on Aardvark's advice.
OT: I've got variac(s) but seldom use 'em for troubleshooting. I find that the 'dim bulb tester' is more useful (and protects the 'test subject' better, too). |
#5 |
thanks
#6 |
Hi John
Not sure on the rating of mine (about an amp) but it works fine I agree with VictoriaGuy but have my Variac setup with a filament lamp in series. Almost covers all bases, just need to add a ammeter. Cheers
If you keep digging in the garden of failure you will eventually find success ![]() |
#7 |
I use the variac in my shop all the time, an ammeter takes the place of a bulb. Either method works.
The variac is used mainly when things are wanting to bow fuses, I don't need it to be able to power the unit under test to its full output. Once we have established that the amp is stable and ready for high power testing, I no longer need what the variac does, and I power the UUT from the wall. All that is the long way to say that I don;t ned a 1000 watt variac to service 1000 watt amplifiers. A smaller one will still be useful. |
#8 |
I always wanted to make a variac test box that had meters for voltage and current and also switches to put in a 100 or 25 watt lamp. Maybe add a receptacle and also binding posts...
#9 |
Like this?
![]() I added a isolation transformer inside to protect the binding posts, would still like to add a ammeter. Lamp can be switched on or off and I just swap the lamps from 40, 60 and 100 watts ![]()
#10 |
I tried using a 2A variac once, and proceeded to blow the windings.
Best to use an over-rated one in case something shorts out. |
Thread | Thread Starter | Forum | Replies | Last Post |
Variac as transformer for LM4780 GC? | brietech | Chip Amps | 9 | 18th September 2007 06:19 AM |
Powerstat Variable transformer / Variac | speaker | Swap Meet | 0 | 16th May 2007 03:20 PM |
Variable resistance transformer preamp | chuck55 | Chip Amps | 9 | 7th November 2005 02:32 AM |
Can a variac replace the power transformer | gnomus | Pass Labs | 9 | 18th December 2002 02:30 PM |
Superior Electric Variable Transformer | CCOZGO40 | Swap Meet | 1 | 28th October 2002 02:41 PM |
New To Site? | Need Help? |
