Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st October 2011, 09:34 PM   #1
Default What's this transistor?
Hi
I have an old kit(door buzzer) and I want to repair it
it has 2 transistor with the name "A1283" and I want to know the whole name of it like, 2SA1283 or.......
Can anyone help me with that???????
Nothing is impossible, you just need to believe this
Old 1st October 2011, 10:06 PM   #2
49 - for the 16th time
c2cthomas's Avatar
I'm not positive - but take a look at this.
2SA1283 pdf, 2SA1283 description, 2SA1283 datasheets, 2SA1283 view ::: ALLDATASHEET :::
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Old 1st October 2011, 10:11 PM   #3
tomchr is offline tomchr  United States
tomchr's Avatar
Yep. 2SA1283.
"50 % of the game is mental and the other 50 % is being mental. I've got that part down, no problem."
http://www.neurochrome.com/audio
Old 2nd October 2011, 04:04 AM   #4
thank you
do you guys know some replacement for this part?
Old 2nd October 2011, 04:07 AM   #5
c2cthomas's Avatar
Look up sub's for it - we will tell you if you are correct.
Old 2nd October 2011, 06:19 AM   #6
wrenchone's Avatar
The data sheets linked here say it's a "TO-92 mod" package with 900mW dissipation, but the device in the picture is clearly a plain-jane TO-92. (?) I would replace it with an MPSW56, or perhaps a 2SA965 (if you can find that one...). Both of those devices are in the long TO-92 package.
Old 4th October 2011, 01:18 AM   #7
Enzo is offline Enzo  United States
One thing to be careful of. There are "American" type nimbers like 2N3904, and "jalanese" type numbers like (2S)C945. And you can find equivalents in both number systems. ANd electrically you can replace one with the other. HOWEVER, the USA types all have the leags arranged as E-B-C, whereas teh Asian types have the leg arrangement E-C-B. SO if you swap one for the other, you will need to turn the transistor sideways so the legs can go in the appropriate holes in the circuit board.
SO if that MPSW would work, just make sure to wire it correctly.
B&D Enterprises at least lists the 2SA1283 as out of stock, but they also say this:
Replace with 2SB647A. But of course they don;t have those either.
Old 8th October 2011, 08:50 AM   #8
Maybe we can find 2SA1283. The only problem is the quantity. Had to find a supplier wich to sell 1 or even 10. 100 pcs for TO-92 transistor is the MOQ in most cases.
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services
Chat with me
Old 8th October 2011, 08:34 PM   #9
SInce it is a door buzzer, I have to think the part is not critical at all, and that the circuit is probably not very sensitive to type here. Of course I have been wrong before. I'd suspect most any PNP transistor meeting the minimal specs ought to work.
Old 9th October 2011, 02:18 AM   #10
wrenchone's Avatar
The approach mentioned is probably the most expedient one. Since the device in the picture is clearly in a standard TO-92 package, any TO-92 PNP with proper voltage/current rating would work in its place. I have no idea what is commonly available in Malaysia, but I'd go with an MPSA56 (with a twist to get the right leads in the right holes as suggested).
Can I build up these Darlington transistor if I use two BJT transistor ? gaborbela Parts 9 15th July 2010 06:30 PM
who knows this transistor? sethiyadav Power Supplies 6 2nd February 2010 07:50 AM
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 23 16th February 2008 12:35 AM
Transistor name ObliVion Everything Else 1 21st October 2004 09:34 PM
Best Transistor? samsagaz Solid State 13 18th October 2004 09:22 AM
Page generated in 0.09178 seconds (78.15% PHP - 21.85% MySQL) with 10 queries
