| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have a Hakko soldering station but no temperature control card. Can someone tell me if I can rig up a card using something else? I tried a playing card, but that didn't work. I took the unit apart and it looks like there are 2 LEDs on one side, and 2 photosensitive elements (I think) on the other side. So.... does the light on both need to be interrupted for it to work? Are there any holes or slots in the original card which would allow one LED to shine through and the other to be blocked? Thanks in advance for any help. Saurav |
#2 |
I made cut out in piece of cardboard to block the second led and let the first see throw. It worked like a charm.
Vlad |
#3 |
OK, which one's the first and which one's the second?
#4 |
It should look some thing like this:
XXX XXXXXXX XXX XXXXXXX XXXXXXXXXXXX XXXXXXXXXXXX Or if you lazy just tape the led that is very inside. Vlad |
#5 |
Thanks. I'll try that out.
| How does OKi MFR soldering station set tip temperature? | speakerguy79 | Parts | 0 | 25th March 2008 08:02 PM |
| Hakko 929 Soldering Stations | damonpip | Swap Meet | 25 | 18th March 2006 08:55 PM |
| Hakko 929 Temp Controlled Soldering Stations | damonpip | Swap Meet | 49 | 8th May 2005 12:38 AM |
| FS: Hakko 929 Soldering Station | damonpip | Swap Meet | 1 | 28th August 2003 03:28 AM |
| Soldering station temperature | raincheck | Parts | 0 | 18th July 2002 05:44 AM |
| Page generated in 0.06057 seconds (82.70% PHP - 17.30% MySQL) with 10 queries |
