| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am wanting to use a Central Semiconductor 1N5314 4.7 ma Current Regulator Diode. My understanding is that a CRD is a jfet and a resistor in series in the same package.
My question (and I feel rather silly to ask) is about the cathode marking on the device. Does the cathode of a CRD get connected to the negative leg of the circuit for normal operation, or is there some notion of reverse bias in analogy to a zener that would mean one really wants to connect the cathode to the positive leg? I would hope it is the former, but I thought safer to ask. The device datasheet I saw is little help. Thanks. |
#2 |
While you're trying to figure it out, be sure to check Walt Jung's website and this 2 part series of articles: http://waltjung.org/PDFs/Sources_101_P2.pdf
#3 | |
Already read that thanks (at least I had read the first part). |
#4 |
Should be normal order, so cathode as the negative pole. Zeners are really the exception in that they operate as Zeners in reverse polarity (and as normal diodes when not reversed).
Good to see that current diodes are still being made, I though they had become obsolete (like the J500 series for example).
Martin Rupp |
#5 |
Usually there is no resistor. These things are ordinary n channel jfets with gate connected to source. Current value is by device sorting during production
#6 | |
#7 |
It's true that using a higher current jfet and selecting a resistor between gate and source does improve the slope resistance and the temperature coefficient
#8 | |
#9 | |
Indeed, the cathode marked leg of the device really does go to the negative leg of the circuit! My application is to bias a pair of OPA627's (following a DAC) into class A. I wired the CRD's tonight and was delighted everything worked the first time and all the smoke stayed in. My eyesight is not what it once was and soldering the CRD's between the DIP pins was quite exciting. So far the sound is good, though I must say the sound was good before. At least the CRD's have not hurt the sonics and have possibly made the performance even better. |
#10 |
Dont forget to take them off .....
| Diode regulator VS IC regulator. | Rembrant | Power Supplies | 5 | 31st May 2011 03:38 AM |
| Need a CRD E-102 (current regulator diode) | ostie01 | Parts | 2 | 10th August 2006 09:13 PM |
| regulator protection diode | starushz | Power Supplies | 12 | 26th January 2006 02:46 PM |
| Using Ixys current regulator as current sink. | G | Solid State | 3 | 16th November 2002 10:23 AM |
| Page generated in 0.10179 seconds (81.17% PHP - 18.83% MySQL) with 11 queries |
