Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th September 2011, 06:26 PM   #1
Default Laptop Internal speakers repair.
I got my laptop internal speakers damaged. And here in India I could not find any replacement. The speakers are electrically ok. I am attaching pic of the speakers. Pl suggest me simple tip that would make speakers audio-able again. I don't expect it to get back same quality or its TS but should be enough good for voice chat.
The tip like using some kind of glue to patch torn part. or some adhesive tape or something.
There is always a first time....
Old 14th September 2011, 06:35 PM   #2
Frank Berry's Avatar
Who manufactured the laptop?
What is the size of the speakers?
What is the speaker impedance (d.c. resistance will give you a good idea of the impedance)?
It looks like the speakers have a foam surround. Not easily repaired.
Frank
Old 14th September 2011, 08:39 PM   #3
Its from a Laptop A215-S7413 from toshiba. Its said the speakers are Harman Kardon make.
yes its only surround is damaged and I am looking to repair or just get this to work.
Old 15th September 2011, 02:34 AM   #4
dangus is offline dangus  Canada
Maybe you can patch the surround using some thin flexible cloth, smeared with silicone glue (aka RTV, silastic, silicone sealant).
Otherwise, can you scrounge similar speakers from an obsolete laptop, or possibly an old mobile phone?
Old 15th September 2011, 02:41 AM   #5
SirByrd is offline SirByrd  United States
SirByrd's Avatar
If you patch surround the rest of it will just fail sooner or later.
I don't know if you can buy foam surrounds that small, you could attempt to make a doped cloth replacement surround, but it would be tricky.
If that is a 1" driver there are a couple of nice ones at partsexpress and they should ship to India.
HiVi B1S 1" Shielded Aluminum Mid/Tweeter
Tang Band W1-1070SE 1" Full Range Driver
Or if those are too expensive you could get a quick fix like this:
2-1/4" Round Mini Speaker 8 Ohm
or this:
40mm Neodymium Headphone Element
also check on MCM electronics.
Old 15th September 2011, 03:47 AM   #6
frugal-phile(tm)
planet10's Avatar
It is hard to replace a laptop speaker because they are often afixed to the required "box" in a manner that makes it difficult to swap anything in... that said i have lots of little laptop drivers, and would be happy to post some if they are appropriate size. Whatever i have the drivers won't necessarily be perfect for the boxes you have to fit them in.
Mail me.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th September 2011, 06:33 PM   #7
Thank you all,
Dave you said it right. we can not replace laptop speakers by any easily available speakers. sometime back when my mom and dad were at US, I bought a pair from ebay, which were said to match my laptop. when my parents got them to India, I found they didn't match. So my search went on for solution.
Dave,I deeply thank you for your such readiness to help. I shall surely get back to you if my current solution fails again.
Solution: I took a bigger adhesive tape cut it much bigger than the diameter of the speaker diaphragm. pressed it against the AA size battery's end. this gave it a bit of conical shape.
then I carefully glued the tape to the cone. and the rest part to the frame of speaker.
This solution worked well for me. I mean, I got what I was looking for. this sounds really ok. vocals can be well followed. the problem is with bass. but then Its ok for me. Now at-least I can use the internal speakers for video calls.
I am attaching the Pic of the speakers with this.
Old 16th September 2011, 04:46 AM   #8
Most Indian metros have speaker repair shops who can fix the problem for u.
Gajanan Phadte
Old 16th September 2011, 05:08 AM   #9
Gajanan Phadte
I did try, they say we do not have speakers for this model. I even visited Toshiba service centers here (Pune). They flatly refused.
Hum through speakers using GC & Laptop zebra100 Chip Amps 22 23rd August 2011 01:39 PM
6 speakers + my laptop KnJ Full Range 19 20th July 2011 03:03 PM
laptop internal speakers mrybczyn Multi-Way 1 25th May 2008 07:26 AM
Amp needed for measuring speakers with laptop JohanH Multi-Way 7 24th February 2005 06:28 PM
What internal wiring to use for speakers? AJ Bertelson Multi-Way 3 17th May 2004 05:59 PM
Page generated in 0.09449 seconds (87.77% PHP - 12.23% MySQL) with 11 queries
