Originally Posted by Ed LaFontaine
The blackened edges and field are to be expected. There is also deposition of combustion products onto surrounding areas. My source informed me to apply the chosen finish onto the woodwork first, thus sealing it and preventing the smoke and ash from entering the pores. The residue wipes off of the surface of sealed wood.
Of course. The deposits just wipe off or might need a light sanding. I was refering to the burned edges of a cutout or field. If what you want is merely a relief without contrast, a laser isn't appropriate. I don't finish first for a few reasons - most finishes are flamable and/or toxic when burned and even though the lasers are vented and cut plastic all the time, I don't necesisarily like to add more toxins to the environment if I can. Also, it will need to be refinished anyway to cover the burned part, so why do it twice? Maybe use sanding sealer for the pores, but no need for a full finish.
Listen to the music through the stereo, not the stereo through the music.
