| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi all.
I have been using for some time now a Large transformer rated 2000va featuring multiple secondaries. Only for high current experiments (peltiers, solid state lasers ecc) ![]() The secondaries range in discrete steps from 6v to 180v. I really have no use now for it since for all experiments I use a 2000va variac. I was hoping this transformer could be transformed for audio use. It is very heavy (25kg) but for a static installation it might be used. unfortunately the windings are as such: 0-6 to 0-180 so no dual voltages with center tap seem available. I am currently exploring tube amp construction and since I would have a 180v + 60v + 6v it might make sense to use it for an enormous PPP design (something like a mesa boogie but on a larger scale). ![]() I also own several 2000uf 200v caps I could use in a build such as this. Anyways any suggestions would be very welcome. Fire away with any ideas! Thanks Alex Last edited by Alexontherocks; 4th September 2011 at 09:34 AM. |
#2 |
#3 |
On other detail and I hope someone can offer some help on this one:
The input wires are green on the transformer. I have 4 leads 1. 210 2. 0 3. 230 4 30 What is the 30v for? is there anyway I can use this input to elevate all the secondary outputs? Thanks Alex |
#4 |
Alex,
are all 4 tappings on the one Primary Winding?
regards Andrew T. |
#5 |
You know sometimes I should really test and test over again before writing....
the 4 wires are all green aas opposed to the secondaries which appeared to be yellow.. However there is no continuity between the 30v (green) and 230(green) but there is between the 0v (green) and the 230v (green). basically the 230 + 0 green inputs are one large input the secondaries therefore range from 0 to 210v (with a color change from yellow to green at 210v) also there is an extra 30v green wire. So basically I have a 0 yellow 6 yellow 12 yellow 24 yellow 30 green + 30 yellow 60 yellow 90 yellow 120 yellow 150 yellow 180 yellow 210 green All the outputs in bold show continuity. |
#6 |
yes...continuity between all yellow leads and yellow + 30v/210v green leads.
NO continuity between all the above values and the 0 - 230v input leads |
#7 | ||
regards Andrew T. |
#8 |
Yes. Also a visual prof of this is that all secondary leads are double which would be expected in case of taps along a single winding. would it not?
I confirm the 230 -0 input leads share no continuity with any other connection on the platic rail connectors. |
#9 |
The Double Wires going into each terminal may mean that the secondary has separate windings and that these separate (two ends to each winding) are connected in series.
Open up one terminal connection that has two wires and split them. Do you now measure two separate secondaries? If you can, check the thickness of every wire going into the terminal block. Check the resistance of every tapping. Is the Primary on a separate bobbin from the secondary?
regards Andrew T. |
#10 |
You see that is why I love thi forum....always learning something new.
The secondaries appear in series. I f a open up the 30v yellow double lead I get no continutuity between the 24v and the 150v (for example). THis is so for every double lead. The thickness is almost 2mm OD per wire... Unfortunately I do not have a thickness gauge here but I would say 2mm is pretty a ccurate (simple metallic ruler used) |
| 2000VA Variac | boywonder | Swap Meet | 2 | 11th May 2009 04:16 AM |
| 2000VA Transformers | bigparsnip | Swap Meet | 12 | 23rd January 2008 05:30 AM |
| Precision Pots, Multitap Transformers | Illusus | Swap Meet | 3 | 5th September 2005 10:02 PM |
| Transformer manufacturer suggestions | needlz | Chip Amps | 1 | 20th April 2005 07:50 PM |
| Page generated in 0.10502 seconds (81.56% PHP - 18.44% MySQL) with 10 queries |
