Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th August 2011, 12:00 AM   #1
gychang is offline gychang  United States
Default need AC outlet hum filter
I have several AC outlets in my music room. I also have 2 amps-speaker combos and found out now that only one AC outlet is hum free. The others result in AC hum with different combination of amp-speakers. I am guessing it may be the home wiring (only 11 year old home).
1. Is there a device I can plug in the AC outlet that will eliminate speaker hum (low volume can't hear, mid volume setting start to hear, and maximum setting quite loud). I use t-amp clone and various diy fullrange speakers.
2. Is there a home structure problem?
thanks in advance
Good sound from Phoenix, AZ
Old 29th August 2011, 03:23 AM   #2
ArtG is online now ArtG  United States
All AC outlets produce hum. That's the nature of 60 Hz Alternating Current.
The very first thing to check would be that your wall outlets are wired correctly. You can do that yourself with a small yellow tester that has three little lights on it. These are available at many hardware stores and "home improvment " stores in the electrical department. They are usually in the range of $5, possibly more today. Instructions come with it. If you find any of the outlets mis-wired, you should have an electrician make the repairs. "Hot-Neutral reverse, and "open ground" are two common issues, and they are both safety issues.
If all your outlets do test okay, then you need to carefully examine the power supply wiring of your amplifier. The hum problem, may be due to incorrect wiring or bad insulation. Again, the hum you hear could also have safety consequences.
Old 29th August 2011, 12:31 PM   #3
Speedskater's Avatar
All your equipment should be plugged into the same dual outlet or power strip.
Is a musical instrument involved?
Kevin
Old 29th August 2011, 12:50 PM   #4
Will stop by Homedepot and get AC tester. I have pretty much eliminated PS or amp source problem, since it is AC outlet dependent hum. (Have about 5 outlets in my music room and one outlet produces no hum).
Old 29th August 2011, 10:33 PM   #5
Enzo is offline Enzo  United States
You can also have a "ground loop." That is where two pieces (or more) of equipment, that are otherwise working just fine, have a slightly different ground potential ontheir chassis, and when you connect them together with a signal cable, the ground/shield of that cable completesd a loop and that tiny voltage difference impresses itself on the signal.
Look up "ground loops," and for that matter "ground loop busters."
Old 30th August 2011, 12:30 AM   #6
got a special AC strip that minimizes hum and it worked!!, realize this is a temporary solution, thanks for all the help.
removing AC Hum on Aikido???? cbutterworth Tubes / Valves 6 24th December 2006 01:27 AM
2A3 AC filament hum bigbulb Tubes / Valves 4 28th July 2005 12:59 AM
AC Hum P901 Parts 2 4th December 2003 11:14 AM
Help with hum in AC heaters HeadSh0T Tubes / Valves 21 27th September 2003 12:40 AM
Page generated in 0.08559 seconds (77.04% PHP - 22.96% MySQL) with 10 queries
