Well, it puzzled me as well!Forgive my NOOB-ness, but how did the manufacturer of the pc speakers it came out of, get it to run stereo? I mean...the channels were correct and it also turned the set on and off. I am just confused.
You are sure there are only 5 pins on your pot, as in the spec sheet you posted?
These pics should help...
https://picasaweb.google.com/102444038593081286951/MysteryPOT?authuser=0&feat=directlink
The chip amp has a DC volume pin. The same pot can connect to each channel's chip amp. The pot adjusts the DC voltage on each pin, likely over ~5V range, and this sets the volume for L & R. The sub may have a similar chip amp, or it may use its pot in the conventional manner. It's likely that the sub pot is after the summing circuit and it is a single-gang pot also.
It's probably not the pot you want for your project, unfortunately.
- Design & Build
- Parts
- Need help idetifying this 50k pot!!!
