| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Everything's in the title
#2 |
Binding posts/banana sockets are generally 3/4" apart.
#3 |
ok, thanks for the info!
what about the RCAs? |
#4 |
same>>>>>> 0.75" or 19.05 mm
#5 | |
Cheers |
#6 | |
cool, can I plug my 4mm bananas in it?
#7 |
Banned
One of my famous audio designer buddies once built a line of amps with the spacing at 1.0", so that no one could use a standard binding post adaptor.
Yep, he did it on pupose because he hates them so much. And to think, some of you guys think that I am the only "wise guy" in the business.......................[joke] Jocko |
#8 |
I'll go for 19mm (19.05 if I can) between the RCAs and the bananas.
With 5 pair of RCA, and 2 pair of bananas, that will be an elegant line
| Banana's Pre - inelegant way to contrl vol | banana | Chip Amps | 31 | 6th November 2007 02:28 PM |
| banana or spade for 12-ga wire | Alex Barnett | Parts | 4 | 29th December 2006 03:48 AM |
| banana plugs | morpheus82 | Parts | 0 | 31st July 2006 03:15 PM |
| Where to find banana connections | ChevS-10 | Subwoofers | 4 | 31st May 2005 05:11 PM |
| Tube sockets with the same pin spacing as the tube | Andypairo | Tubes / Valves | 5 | 15th March 2004 01:08 AM |
