Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th August 2011, 11:34 PM   #1
Default could someone who understands potentiometers please explain something to me
Hi, please be kind, it's my first post.
So i need to replace a potentiometer that's been crackling in a joe meek, twin q preamp. I've pulled it out, the manufacturer is alpha, printed on it is '10c5k' and stamped on the back is '7g2' What confuses me most is the 'c'. I have deduced it refers to the resistance taper. looking at the manufacturers taper specs it appears that taper type 'c' is a reverse audio taper. On the preamp it acts like a regular audio taper, hard left is 0 hard right is 100. why is this? I was hoping to replace it with a linear type 'b', as i prefer the feel of linear for my gain knobs, but will this make it backwards?
Thanks for reading through all that, your time and advice is really appreciated
Old 14th August 2011, 11:59 PM   #2
Pano is offline Pano  United States
Pano's Avatar
I'm not sure why they would have used reverse taper, I mostly see those in balance controls. But someone may step in with the answer.
A linear pot will not give you a linear feel, quite to opposite. That's what the log curve pots are all about. But a linear will work, for sure.
Old 15th August 2011, 12:06 AM   #3
It is most likely in a feedback circuit, so the action is reversed. You probably do not need to replace the pot, use a chemical like De-Oxit on it. If it actually has a burned spot then you should look for DC on the pot wiper, most likely from a leaking electrolytic capacitor.
Old 15th August 2011, 12:16 AM   #4
Thanks simon, i figured it was something like that.
Now i'm more confused as to why a linear pot wouldn't give me a linear feel. i want it to act like, hard left 0% middle 50% and hard right 100%. at the moment its like hard left 0% middle about 30% hard right 100%
Old 15th August 2011, 12:48 AM   #5
DJNUBZ is offline DJNUBZ  United States
The reason is that Audio isn't linear, it's logarithmic. To gain 3 db you must double your power. Personally i have replaced some faders on a mixer with log pot and found that I didn't like the way they performed so I switched to the linear pot. On something like a preamp, where you aren't adjusting that much I don't think it will change how you use it much either way.
Old 15th August 2011, 01:00 AM   #6
ok, i think i understand. so is there any way i can make it "feel" linear. like 3=30% 8=80% ? at the moment i have very little precise control after about 70%. even very small adjustments on the knob, make huge adjustments to the sound.
Old 15th August 2011, 05:07 AM   #7
digits's Avatar
you can try to wire up a fake law pot, or just buy a logarithmic pot.
potentiometers imsellingmyfoot Chip Amps 10 7th December 2010 03:21 AM
Potentiometers aMateRasU Solid State 18 16th November 2010 09:17 AM
C and L of potentiometers? Christer Parts 2 26th June 2007 11:26 AM
Potentiometers slogan2112 Solid State 2 19th December 2003 06:54 AM
Page generated in 0.09056 seconds (76.46% PHP - 23.54% MySQL) with 10 queries
