Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th August 2011, 07:30 PM   #1
vann is offline vann  Macedonia
vann's Avatar
Default Cabling and connectors
I have a few extra pairs of RCA jack connectors... I know they are best used for the inputs, but can also I use this kind of connectors for speaker outputs? (the output power should never exceed ~20W per channel)
Another thing is, I plan to use Cat6 ethernet cable (full copper type) for connecting the speakers to the amp (as suggested in Full Range forum, if I remeber correctly). Can/should I use the same for connecting the amp to the source?
Old 10th August 2011, 11:14 PM   #2
Speedskater's Avatar
Well you can and many small powered speaker systems do. In the far distant past HAM radio operators used them for antenna connectors at well more than 20 Watts. But they are a poor choice for any propose.
Kevin
Best type of wire for re-cabling AKG 701's .. anyone do this? NOTFRAGILE Headphone Systems 18 15th December 2011 07:39 PM
Power supply cabling rsumperl Tubes / Valves 2 1st September 2010 04:51 PM
Need your ideas for ES headphone cabling j beede Planars & Exotics 3 30th January 2008 06:27 PM
Power supply cabling smithy666 Solid State 1 24th April 2007 12:22 AM
Which cabling to use? matthew2456 Tubes / Valves 9 11th August 2006 08:42 PM
Page generated in 0.05966 seconds (68.07% PHP - 31.93% MySQL) with 11 queries
