Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Hook Up Wire Suggestions?
Old 26th August 2003, 04:46 PM   #1
Tom D is offline Tom D
Default Hook Up Wire Suggestions?
I'm going to be hooking up some new RCA chassis-mount jacks on an amplifier that I'm working on.
Can anyone suggest some good quality hook-up wire that would go from the jacks into the circuit board?
Is there any particular Gauge, Solid vs. Stranded that is recommended?
Thanks. Tom
Old 26th August 2003, 05:57 PM   #2
jackinnj is offline jackinnj  United States
jackinnj's Avatar
CAT5 cable is usually very high quality and pretty inexpensive -- there are 8 color coded conductors -- it solders up very -- the only adverse thing I can say is that it seems to snap if you nick it with your diagonal wire snips.
Old 26th August 2003, 06:19 PM   #3
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
CAt 5 is not that bad. If the insulation is not teflon i'd rather strip it. Kimber hookup is very cheap and much better.
Old 26th August 2003, 06:22 PM   #4
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Hook Up Wire Suggestions? Send a message via AIM to Peter Daniel
And Cardas is even better, but you need solder pot to terminate it.
I like to work with Kimber wire as it's very user friendly, but in some critical locations, recently, I started to enjoy Cardas much more.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 26th August 2003, 06:29 PM   #5
tiroth is offline tiroth  United States
Peter, you are referring to the Cardas hookup wire? (so many suppliers seem to sell Cardas wire under various names, and Cardas' site doesn't seem to identify all of the wire-only variants)
What about a hefty (100W) iron? I usually just burn the enamel off of magnet wire...
Old 26th August 2003, 06:32 PM   #6
sam9 is offline sam9  United States
sam9's Avatar
Since these are low level input leads, you may want to consider something a little different for them, namely comekind on shielded wire.. Because they are low level, they are particularly suseptable to picking up unwanted signals such as humm from the power supply, x-talk from the other channel's input. They can even interact with the output from the same channel and induce oscillation.
None of these are inevitable. In fact layout can avoid most of this (a few inches or air cost nothing and isolates fairly well). Still it is a precautionary measure that does no harm.
I don't think the kind of shielded wire is all that critical. I've found a few inches cut from a spare interconnect cable works fine. RG59 coax is probly good to but nuch stiffer.
Old 27th August 2003, 12:36 AM   #7
I buy the wire from local Cardas rep, but Partsconnexion and Michel Percy sell them under cardas name. I use 20 (or 19) ga. It could be probably possible to use high power iron, but the pot is much more convenient.
My comparison between Kimber and Cardas is that Kimber is more laid back and lacking space, while Cardas is more lively with bigger soundstage (and maybe coloration?). I used Kimber silver wire (same type as TSS) and it's really good, especially in interconnects like Silver Streak.
www.audiosector.com
Old 27th August 2003, 03:55 PM   #8
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
19/20 g seems awefully thick for internal wiring -- Have you tried anything skinnier? I use 30 g wire wrap wire or similar guage magnet wire -- you need the trick wire strippers to deal with the WWW so you don't nick it (it works well with the Cat 5 wire too).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th August 2003, 04:03 PM   #9
PhopsonNY is offline PhopsonNY  United States
PhopsonNY's Avatar
Default Try this
I have used this and was quite happy.
Not too expensive either
http://www.referenceaudiomods.com/Me...gory_Code=WIRE
Hook Up Wire Suggestions?Hide this!Advertise here!
hook up wire Burnedfingers Parts 5 12th January 2009 06:34 AM
Hook up wire? cjkpkg Parts 12 23rd November 2008 11:55 AM
carol PVC hook up wire EZ_Angus Parts 6 5th May 2004 12:56 AM
Hook-up Wire? mwh-eng Tubes / Valves 6 4th March 2004 07:30 AM
Hook-up Wire Cambe Parts 0 2nd October 2002 04:58 PM
Copyright ©1999-2017 diyAudio
