Finding parts - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th August 2011, 01:17 PM   #1
h00hbt's Avatar
Default Finding parts
Hi all
Im trying to locate where I can find some parts for my amp. One part seems very difficult to find. Itīs a "semi tube rivet" that I want to use when making a inlet thrugh the wooden schassis to enable setting a fixed bias. This "semi tube rivet" would schield the hole and guide the tool to set the bias. Anyone know where to find such a thing? Also, Im trying to find some kind of testingpoint that could also be fitted thrugh the top plate of the schassis....
Cheers
/H
Old 7th August 2011, 02:41 PM   #2
Frank Berry's Avatar
These might work for you.
How do you plan to mount the bias adjustment pots?
Frank
Old 7th August 2011, 03:08 PM   #3
Ty_Bower's Avatar
Originally Posted by h00hbt View Post
Also, I'm trying to find some kind of testingpoint that could also be fitted through the top plate of the chassis...
Mouser has a ton of them.
Mouser Electronics - Electronic Component Distributor test point
Old 7th August 2011, 03:25 PM   #4
h00hbt's Avatar
The pots are mounted on a PCB so I will mount the PCB on the inside of the schassis. The part you found could work but I think something thinner aprox 4mm diameter.Where did you find it?
/H
Old 7th August 2011, 03:25 PM   #5
h00hbt's Avatar
Originally Posted by Ty_Bower View Post
Hey! Thanks, they will be fine.
Cheers
/H
Finding discontinued parts n0ukf Everything Else 0 28th January 2011 08:00 PM
Need help finding replacement parts hatrack71 Solid State 1 5th May 2009 02:46 AM
Can I get some help finding parts/catagories? Destroyer OS Parts 2 4th February 2006 03:05 AM
Copyright Đ1999-2017 diyAudio
