| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm going through the parts list of an HP 333A Distortion Analyzer (~1985) and I'm reading something odd.
Cap: Fixed aluminum electrolytic 50uF +100% -10% 6vdc Capacitors back then really had such bad tolerances? I mean +100% sounds pretty unreasonable in something like a distortion analyzer. This would lead me to believe recapping the beast with modern caps would significantly reduce its drift and improve performance? Thanks. |
#2 |
Yes they did have such poor tolerances in the past. Basically to guarantee say 66uF 90% of the time you would build say 100uF caps, sold as 66uF. Selection seems obvious, but values drift over time, initially quite quickly. However the issue totally depends on what the cap is doing. If its a coupling cap for say 5Hz roll-off then -10% is 5.5Hz, + 100% 2.5Hz, and the wide specification barely effects the analyzers performance. Also the spec for the part may not remotely reflect the part used. rgds, sreten. I'm not sure recapping would improve an analyzers performance that much, but it depends on what you use for and how you push limits.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 6th August 2011 at 11:57 PM. |
#3 |
The standard back then was + 80% -20% didn't know there
were other call outs... Steve @ Apex Jr. |
#4 |
Thanks sreten, this unit is turning into a little history lesson for me.
@Apex: It seems to have caps of like...every tolerance. The ceramics seem to be 80,20, mica are +-5, tantalum +-10...best I've seen is a +-2% mica. Not bad. |
#5 |
-20 and +80 is common and no doubt looser tolerances existed. My usual advice is to prove a cap is bad before replacing it, but I've had such poor luck with 6V electrolytics, I'd automatically replace them with new. If there's any way it would fit, I'd go with 16V, as the 6V jobs are generally inferior right from the start. It seems like almost every piece of test equipment I've worked on that used 6V caps, needed them replaced. They can also fool you on measurement, as a crazy high dissipation factor will show up as a normal or even higher capacitance measurement; you won't know this if your meter doesn't read DF!
I used to be an audiophool like you but then I took an arrow to the knee. |
#6 | |
G² |
#7 |
I've got an ESR meter on the way. I'm at a point where I have a bunch of vintage audio stuff that probably needs recapping but I figured why change them all if some are all right. Saves me time and money. Or at least it would make me feel better to know the caps I'm changing are actually in bad shape. If I'm lucky I might hear a difference too.
| Stupid electrolytic cap question....... | firenewt | Tubes / Valves | 4 | 24th October 2006 12:26 PM |
| Electrolytic Cap Search | Peter Menting | Tubes / Valves | 3 | 5th May 2006 02:40 AM |
| Electrolytic cap question (not quite covered elsewhere) | Puggie | Parts | 5 | 15th March 2006 03:23 PM |
| can I use an electrolytic cap as coupling? | Nordic | Chip Amps | 2 | 20th September 2005 09:12 PM |
| Page generated in 0.08719 seconds (78.14% PHP - 21.86% MySQL) with 10 queries |
