| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Happy Chappy
Sorry to be a total noob
I’m starting my first DIY Audio project; I have followed the links on here to http://tangentsoft.net/audio/cmoy-tutorial/parts.html#req And I’m looking at the parts list .. so the first on the list is 220 µF/ 35 V electrolytic capacitor, radial leads Now I have found something similar on the CPC site , and as its only 6 miles away I thought it should be my first port of call, but I didn’t find anything that went up 220 µF , so I take it the one below is nothing like the one needed for the build ? Also this was 1.3 ohm .. I noticed that there was a whole list of ohm ratings how much does this alter the part ? http://cpc.farnell.com/_/cb1v226m2lcb/capacitor-tant-22uf-35v/dp/CA05701 Description · CAPACITOR, TANT 22UF 35V · Capacitance:22µF · Capacitance Tolerance:± 20% · Capacitor Application:General Purpose · Capacitor Case Style:Radial Leaded · ESR:1.3ohm · Lead Spacing:5mm · Operating Temperature Range:-55°C to +125°C · Voltage Rating:35VDC · Body Diameter:9mm · External Length / Height:14mm · Impedance:1.3ohm · Impedance Frequency:100kHz · Impedance Temperature:20°C · Lead Diameter:0.5mm · Leakage Current:6.1µA · No. of Pins:2 · Operating Temperature Max:125°C · Operating Temperature Min:-55°C · Package / Case:Radial · Series:MCCB · Terminal Type:Radial Leaded · Termination Type:Radial Leaded · Tolerance +:20% · Tolerance -:20% · Voltage Rating VDC:35V |
#2 |
That 220µF/35 V is an electrolytic capacitor and not tantalum. Tantalum should not be used.
Gajanan Phadte |
#3 |
Happy Chappy
Thanks for the reply I now have a better idea about the parts
| New Speaker Parts for a future Project | form109 | Multi-Way | 5 | 28th June 2010 10:49 AM |
| lots of project parts ... | Lagroute | Swap Meet | 2 | 29th August 2006 09:30 PM |
| choosing parts for a dac project | ronardi | Digital Source | 1 | 4th July 2006 06:29 PM |
| Amp Board Project for Parts | speaker | Swap Meet | 0 | 22nd August 2005 01:02 AM |
| Premium parts for your Son of Zen project. | CCOZGO40 | Swap Meet | 1 | 10th August 2002 04:05 PM |
| Page generated in 0.08258 seconds (77.85% PHP - 22.15% MySQL) with 10 queries |
