| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Anyone ever use a Jensen input transformer in a preamp? If so, where should it be located? The Jensen site is unclear about source impedance requirements. Assuming source impedance should be small, it would seem that the transformer should be placed before the volume control. This way, the volume control could always provide a load impedance greater than the required 10K ohms. However, the load would vary with volume selection.
If, on the other hand, the transformer is placed between the volume control and the amp, the idea load of 10k could be had, and it wouldn't change. However, the source impedance would be higher and variable. My hunch is that the first layout would be preferable, but not sure of the tradeoffs. Anyone know? I'm not a big enough customer for Jensen to answer my question. |
#2 | |||
And you wouldn't want the pot to provide a load greater than 10k, at least not for the 11P-1 and 11P-1HPC if you want to avoid using the RC damping network. These two are both ideally loaded with a 10k resistive load so using either of these with a 10k pot or attenuator would be ideal. You might also want to consider the 11P4-1. It's ideally resistively loaded at 20k and also provides a wee bit of voltage gain compared to the 11P-1's 3dB loss. Quote:
se |
#3 |
I am using a fixed series/switched shunt. That is why I'm having questions. I anticipated having to use the RC damper if the transformer is placed before the volume control.
The control will always be above 10K load. As I said, I can get an ideal load if placed after the lineamp, but I'm unsure of the variable source impedance from the volume control. Can't find any info on source impedance issues. I do not need any more gain with horn loudspeakers, but the 20K load of the 11P4 looks interesting. I wrote them over a week ago, and got no reply. |
#4 | ||||
Basically, increasing source impedance will result in increased distortion (primarily at the lowest frequencies), reduced low frequency bandwidth and higher losses. I think you'd be better off with the transformer feeding your volume control. That's really where you'd want it anyway. If you put it after your volume control, then you lose the advantage of ground isolation. Quote:
If you'd like, EMail me the name and EMail address you used to contact them and I'll look into it for you. se |
#5 |
I looked at the 11P4-1. The specs aren't as good. Even with a 20K load, the input impedance of the transformer is not as high as with 11P1 with a 10K load. Also, the CMMR specs aren't as good.
I deduced from the specs that a higher source impedance degrades CMRR. Thus, it would appear to be better to place xformer before volume control to benefit from the low output impedance of a source, and use the RC damper. I made a stepped volume control designed with a 12K series impedance (before contemplating a xformer). This can be either single-ended or balanced. I will probably use two 6K series resistors on either side of the switched resistor to feed a balanced lineamp. (However, I read somewhere that the secondary of the transformer is not balanced, so I don't know if this would be that useful. Perhaps that is why all the application notes show the secondary grounded at one end.) BTW, what is your take on the transparency of these transformers? |
#6 | |
diyAudio Senior Member
If you want to take further advantage of the balanced properties of the xformer you'll need a balanced stage to feed into. Cheers,
Frank |
#7 | ||||
![]() se |
#8 | ||
For an electronically balanced input to get the same performance from a balanced source that a transformer can give you from an unbalanced source, you pretty much have to match the source impedances to a rather high degree of precision. se |
#9 | |
Maybe Jensen should broaden their range and include some real xformers? Ok, they have their uses...nothing there that appeals to a difficult customer like me however. No offense to you, ![]() Cheers,
Frank |
#10 | ||||
For inboard, like I will be using, I guess you just leave the white wire disconnected if the case is conductively mounted to the chassis, such as with the new case style that can more easily mount the transformer in a hole in the back of an amp case, with the wiring easily feeding through the mounting hole to the connectors. (This conductive mounting doesn't square with AS089, but all in all, probably doesn't matter.) |
| Jensen JT-11P-1 Line Input Transformer | csrote | Analog Line Level | 0 | 13th December 2008 10:40 PM |
| Group purchase for Jensen input transformer | pooge | Group Buys | 66 | 23rd May 2006 05:17 AM |
| Page generated in 0.16793 seconds (87.30% PHP - 12.70% MySQL) with 11 queries |
