| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi Guys,
I am attempting to make some modest upgrades to my CA 640c V1, CD player. I contemplating upgrading the RCA outputs. Please see attached image. Does anyone have any advice or recommendations? Kind Regards Dom Last edited by dimdom; 10th June 2011 at 08:41 AM. Reason: Spelling mistake! |
#2 |
Not really is the honest answer. They look OK tbh. Apart from a feel good factor I don't there would be any benefits and unless you had something physically idenetical it would not look good and could in fact be worse if you had to hard wire etc.
For real sonic improvement perhaps investigate such things as the type of opmps used and see if anything there could be a worthwhile improvement.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
Do it. Do it.
If you are confident that you can solder new RCAs on a printed circuit board, surely you can solder in new opamps! |
#4 |
Thanks for the replies gents,
I may leave the RCA outputs alone unless I come across some exact upgraded replacements. I have already removed the opamps and soldered in 8pin sockets whcih will allow me to trial a number of different op amps. Cheers Dom |
#5 | |
What opamps are fitted on this as original ? and what do you plan on using ?
#6 |
Hi Mooley,
teh originals are NE5532's. I have some OPA13XX'S lol I can't remember what I ordered right now. Also heard the LM4562's are pretty good also. Cheers Dom |
#7 |
The 5532 is a dual opamp. OPA13 "something" sounds like a single... no good.
I would suggest... particularly with you having sockets... that you try the TLO72. If you like that then try something such as OPA2604. These are both FET opamps. The 4562 is the successor to the 5532... must admit I haven't tried these. Also consider the OPA2134.
#8 |
Hi Mooly,
I am pretty sure it was the an OPA dual version I purchased. I have the info at work, can't quite remember now. ![]() I'll let you know what they were when I get them, lol. I am thinking about replacement regulators also? Cheers Dom |
| How to add an extra set of RCA outputs | rg24 | Analog Line Level | 4 | 6th February 2011 05:30 AM |
| Multichannel DAC with 5+ RCA outputs | Aetherion | Digital Source | 8 | 17th July 2006 04:53 AM |
| RCA outputs to speaker cables? | otokomae | Instruments and Amps | 9 | 12th September 2005 12:54 AM |
| Kenwood KDC-MP625 No RCA Preamp Outputs.. Any ideas??? | jefferzzzz | Car Audio | 2 | 24th December 2004 08:36 PM |
| PCB mounted pots... | massappeal129 | Parts | 3 | 7th March 2003 12:35 AM |
| Page generated in 0.09971 seconds (77.22% PHP - 22.78% MySQL) with 11 queries |
