| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello,
I'm just starting on my first DIY build, a PSU for my naim preamp and I have a newbie PS transformer question. I'd like to feed my preamp with 2x 24v rails and the design I am emulating, uses a single transformer with dual centre tapped secondaries. A cheaper alternative would be for me to get two regular off the shelf transformers and have each one feed one rectifier each before each rail is then smoothed and regulated like above. I from my limited understanding I think I can wire a 2x ??v transformer (in series?) to emulate a centre tapped V-0-V. My question then is in order to get a 24v-0-24v output, would I need a 2x 12v transformer or a 2x 24v transformer? I've looked at this diagram but am confused as to which voltage transformer I need. Many thanks Last edited by deltaunit; 9th June 2011 at 01:04 PM. |
#2 | |
A schematic of your circuit and power requirements of your preamp would be helpful to provide more specific info.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#3 |
Thanks Sofaspud. I'm struggling trying to understand transformers so haven't gotten very far yet. Maybe I phrased my question incorrectly as a result. I'm looking for 24v in at each rectifier to give about 34v out going into the regulators (superteddyregs) with a voltage drop back down to around 24v going into the preamp. I'd like to use only half the bridge rectifier (only two diodes) and get full wave rectification like in the diagram.
Afaik the preamp only pulls around 10 or 20ma per rail. I am a little confused by why joining 2 12v secondaries in series gets you 24v (according to the diagram) but centre tapping doesn't... If that has cleared anything up is it definitely 2x 24v transformers I need? Cheers, |
#4 | |
#5 |
Im confused too. Your preamp needs 24-0-24 regulated?
In that case you get 48v centertap with 4 diodes. Its either that or 2 24v secondaries with each secondary needing 4 diodes. http://www.williamson-labs.com/image...y-dual-307.gif |
#6 |
Thanks again Sofaspud
Yes, I probably phrased that wrong, it needs two +24v rails. |
| Transformer wiring question, series, parallel and center tapped | swin1 | Power Supplies | 12 | 7th November 2008 07:58 PM |
| Quick output transformer wiring question | wicked1 | Tubes / Valves | 4 | 30th April 2008 03:56 PM |
| 3886 Transformer wiring stupid question | thermonuclear | Chip Amps | 2 | 16th September 2005 05:38 PM |
| power supply transformer wiring question | paulspencer | Solid State | 8 | 29th August 2005 03:38 AM |
| Transformer wiring question | needlz | Chip Amps | 6 | 4th May 2005 05:05 PM |
| Page generated in 0.09505 seconds (81.19% PHP - 18.81% MySQL) with 10 queries |
