| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I need some varistor diodes that appear to be obsolete.
1.3V, - 4mV/degC. Both the the original Hitachi KB265 and the Panasonic MA2C029WB appear to be obsolete and not available anywhere. Does anyone know of a source for these or for an equivalent diode? Thanks |
#2 |
Well I'm going to hold my hand up and say I have never heard the term "varistor diode" before.
Your description 1.3V, - 4mV/degC. sounds like a series connected pair of silicon PN junctions... in other words two diodes in series. Around 2.1mv/K is the temperature coefficient of a silicon junction so 4mv/K and a volt drop of (2*0.65v) sounds just like two diodes. Are they used for biasing an amplifier output stage ?
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
Here you go:
http://www.datasheetcatalog.org/data.../MA2C029WA.pdf Panasonic calls it a variable resistor. Philips calls it a "stabistor". We call it hood, they call it bonnet It's an epitaxial diode with a tightly controlled and specified forward drop and temp coefficient of the drop. It comes in many voltages and coefficients, not necessarily multiples of a "diode drop". |
#4 |
Thanks for the link...
Don't know what to suggest really. Depends what its used for exactly. Maybe investigate using a programmable diode or an arrangement similar to a normal vbe multiplier but using a resistor to modify the characteristic. Without seeing the application its hard to advise
#5 |
The diode is indeed used for bias, in the phase splitter. It is NOT thermally coupled to the transistor it biases, only in the general vicinity. It is hard for me to guess the original intent of using a special part as opposed to the regular diodes they used in the driver stage.
#6 | |
#7 |
Here you go. Top middle, double diode symbol labeled KB-265.
#8 |
That should be an easy one to resolve... but lets just go over the theory and try and do it properly.
Q503 is a constant current source in a classic text book arrangement. Now you mentioned that these diodes can have a volt drop other than the normal multiples. Just studying the data sheet, and its almost as though these are diode multiples but with a series resistor too. Just looking at the forward volt drops at 1.5 and 50 milliamps in thinking that. In your amp the current in the diode is constant and so the volt drop (whatever it is) is essentially constant too. So first question, is the other channel OK and if so can you measure the drop across a known good one ? Two normal diodes would give around 1.4volts. Subtract the 0.7 base-emitter drop of the transistor and you have 0.7 volts across 150 ohms. Around 4.6 milliamps in other words. Also is Q504 in thermal contact with the output transistors ? Thats the normal 99.999% of the time way of ensuring thermal stability with a normal vbe multiplier. I can't really see the tempco of the double diode being used in this regard as a means of control. Using two diodes (perhaps with additional series resistor) and altering the value of the 150 ohm would allow you to set the current to any desired value. It is vital that the preset is readjusted to give the correct output stage current as even a tiny change in the absolute value of the current flowing in Q503 will alter this.
#9 |
Mooly, as I stated previously, the varistor diode is not in thermal contact with any transistor, just placed physically next to the transistor it's biasing (Q503).
The other channel was functional, but the way the power board is attached to the power transistors/heat sink and chassis, and the many connections, make it a long ordeal to connect/disconnect everything for testing. I also have no certainty that the other channel has the original part, so I'm going to replace both. The KB-265 data sheet suggests that the forward drop is less than 2 diode drops, so perhaps it was selected specifically for its forward drop rather than thermal characteristic. I can only guess at the intent, so I would rather find an original or equivalent part. |
#10 |
It was Q504 that I was wondering over being in thermal contact with the outputs
If you are replacing both diodes then you have two choices... Either obtain the originals or fit two diodes and confirm the circuit operates correctly. Have you any concerns with doing that because there is no risk ? I would just advise the bias pots be set initially to minimum bias (which is max resistance of pot) first. The data sheet in your link shows MA2C029WB as having a drop of 1.26 to 1.36 volts at 3milliamps. Thats bang on the mark for two series diodes. Not sure what voltage your amp runs on but with 63 volt caps I would guess say -/+40 volts. That gives around 2 milliamp through the diode... perfect.
| Replacement output transistors and varistor | dynasor | Solid State | 9 | 5th November 2011 08:21 PM |
| Looking for some Diodes | JoergST | Chip Amps | 2 | 31st August 2009 09:16 AM |
| diodes | changsecho | Solid State | 1 | 31st May 2008 04:32 PM |
| Page generated in 0.11386 seconds (76.88% PHP - 23.12% MySQL) with 11 queries |
