Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th June 2011, 03:16 PM   #1
merlin el mago's Avatar
Question Russian FT-3 capacitors outer foil?
Who knows wich one is the outer foil in Russian FT-3 caps, is where I marked the value or the other side?
Old 6th June 2011, 03:33 PM   #2
zigzagflux's Avatar
I have tried identifying the outer foil with my scope, and have not been successful. Works very well for other film caps, just not the FT-3, FT-1, or K40Y. The outer casing likely shields the effect; hence you will likely not realize a difference when inserted into your circuit.
I have also not noticed a difference with the cases grounded or floating.
Old 6th June 2011, 04:08 PM   #3
Thank you
Old 12th July 2011, 08:00 PM   #4
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Hi zigzagflux
I am now prepared to experiment with two FT-1 caps on my phonos.... Have you tryed those ?
What about it´s outer foil ? Is it important ?
Ricardo
RC
Old 12th July 2011, 10:32 PM   #5
zigzagflux's Avatar
See my above post regarding the FT-1's
Old 13th July 2011, 07:49 PM   #6
RCruz's Avatar
Thank you so much zigzagflux
RC
NOS Capacitors(russian, phillips), Russian tubes, SS amp kits, power TX rvrazvan Vendor's Bazaar 0 26th May 2011 04:32 PM
WTB - Russian FT-1/FT-3 capacitors lil' knight Swap Meet 1 1st September 2010 05:06 PM
Outer foil k40y-9 12dodeca Tubes / Valves 4 4th May 2009 11:37 PM
Input cap - outer foil end? Nordic Parts 14 24th March 2006 02:38 PM
WIMA FKP, any idea which end is outer foil ? sceglar Digital Source 12 16th October 2005 07:17 PM
Page generated in 0.07482 seconds (78.16% PHP - 21.84% MySQL) with 10 queries
