| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am replacing the voice coil assemblies on my Audax TW034X0. The replacements (RW034X0) do not have the polarities marked as fas as I can see. Is there a way other than using a battery to determine the polariy of the replacements?
#2 |
No problem : Holm impulse, Arta, Rew, any, just check in what direction the impulse starts
But some drivers/soundcard combinations inverse the polarity. To make it clear check with an other driver where + and - are clearly positioned. |
#3 |
Honestly, a battery is the way to go. It's quick, simple and won't harm anything. I use two AA cells in a holder with flying leads for domestic drivers, and a PP3 for pro drivers. I've tested hundreds, and never broken anything yet.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 |
That's right Pink, but sometimes with tweeters it's harder to see something...and I don't even think of compression drivers...
#5 |
Even easier, just test after fitting the new diaphram, before putting the back cover on.
#6 |
Thanks for the replies. I will do the battery method. Seems strange that the factory does not mark the polarity.
| Audax 34mm Tweeter TW034X0 vs old HD13D34H | maessen | Multi-Way | 6 | 8th August 2011 06:03 PM |
| Voice coil replacement on vintage Wharfedale 12" | flyingtele | Multi-Way | 14 | 24th December 2010 11:17 PM |
| Advice on DIY voice coil replacement | Mayank | Subwoofers | 13 | 31st May 2009 06:48 PM |
| WTB: Audax TW034X0 tweeters (Pair) | atomicmist | Swap Meet | 0 | 4th November 2008 04:14 AM |
| Single Voice Coil Vs Double Voice Coil Subwoofer | Workhorse | Car Audio | 6 | 12th April 2007 06:36 AM |
| Page generated in 0.08885 seconds (76.67% PHP - 23.33% MySQL) with 10 queries |
