Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th May 2011, 01:52 PM   #1
gychang is offline gychang  United States
Default rotary SPDT switch? where?
I am working with t-amp clone (Helder's TA2024 amp) and trying to get a rotary 2 way RCA input switch installed, but being a newbie can't locate one. I see plenty of toggle switches...
can someone direct me to a website with the item?
thanks,
gychang
Good sound from Phoenix, AZ
Old 11th May 2011, 03:58 PM   #2
Boofers is offline Boofers  Canada
Try digikey.com. Search for spdt, select rotary switches, they have a few. Have fun.
Old 12th May 2011, 12:47 PM   #3
is this the correct part for my t-amp, as the 2 input RCA selector switch?
Digi-Key - CKN9487-ND (Manufacturer - A11405RNZQ)
Old 12th May 2011, 01:57 PM   #4
macboy is offline macboy  Canada
I am not familiar with the Hedler TA2024, but I assume it is stereo. In that case you need a DPDT switch. In that case the SPDT switch you found will not work. Try searching Digi-key (or mouser or newark) for "rotary dpdt". If however, this is a mono amp, then you only need SPDT and that switch will work. I see in the datasheet that the "N" in the part number means non-shorting (break before make) which is what you want.
Old 12th May 2011, 07:37 PM   #5
thanks for helping, I appreciate your input. I should definitely have DPDT switch since it is stereo.
second from the bottom on this page correct item?: Rotary | Digi-Key
gychang
Old 12th May 2011, 08:45 PM   #6
Banned
I've got a box full of them. E-Mail me at Andy815408@talktalk.net and I'll send them to you at cost of postage.
Old 12th May 2011, 08:48 PM   #7
email sent. gychang
Old 15th May 2011, 12:50 PM   #8
Default most switches adjustable?
I am not familiar with the Hedler TA2024, but I assume it is stereo. In that case you need a DPDT switch. non-shorting (break before make) which is what you want.
Being new at electronics I learned 3P4T rotary switch maybe adjustable!! I wanted just 2 RCA input on my stereo amp.
My question is are all selectors (e.g. made for 4 inputs) adjustable to accomodate just 2 inputs? How can I tell, seems like some do not mention.
gychang
Old 15th May 2011, 02:18 PM   #9
bill_a is offline bill_a  United States
OK, lets stop and look at this carefully. You want to switch 2 stereo input sources into your amp, right?
A 3P4T means 3-pole, 4-throw (or position).
So, for each source, you need 2 poles because they're stereo. A 3 pole switch will work - you just don't attach anything to the other pole.
The 4 position will work as well, it's just that nothing will be connected to your amp in 2 of the positions. If you decide to add other sources in the future though this is actually a good thing. Some multi-position rotary switches have a moveable stop that lets you choose how many positions you can select. If your switch has this feature, great, use it. If not, it'll still work, but just not as nicely.
Bill
Old 15th May 2011, 04:40 PM   #10
Bill
thanks reply. Yes I realize I don't have to solder wires on RCA input 3 or 4. But I don't want rotary switch to click into those positions... So just default position 1, and another position.
Does the 3P4T or 3P3T or whatever usually have mechanical device that prevent from going beyond the 2nd position?
thanks,
gychang
rotary switch DonsC Parts 0 21st November 2010 01:46 AM
rotary switch woodturner-fran Parts 5 9th February 2008 09:04 AM
Rotary on/off switch kestrel200 Parts 2 23rd April 2006 09:23 PM
Using a spdt switch to select between triode mode and pentode mode on a guitar amp. G Tubes / Valves 19 15th March 2006 09:15 AM
Rotary switch Freddie Solid State 1 30th August 2001 07:55 PM
Page generated in 0.10792 seconds (81.46% PHP - 18.54% MySQL) with 11 queries
