| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
No problem identifying the filament wires, rectifier wires, and HV out wires, but there are three primary wires. Black, black/red, and black/yellow. What's up with that and how do you wire it? Came out of an old organ. Only code on the trafo is C512-41.
#2 |
Measure the resistance between each wire, and each wire and the frame and report the results.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#3 |
What you have is a tapped primary. The black wire is the common connection. The black/red and black/yellow are the hot taps. Generally what these are used for is to give the transformer 115v and 125v taps. Measure the resistance from the black wire to the other 2. The one with the highest resistance will be the higher voltage tap. I would expect the resistance to be nearly the same for both taps, just a small difference.
Its possible that it could be a 120v / 240 volt setup. If the black wire to black/yellow reads 30 ohms for example and the black to black/red measures 60 ohms then the black/yellow is the 120v tap and the black/red is 240v. BZ |
| Trying to figure out how to get this less boomy... | Nazo | Subwoofers | 41 | 2nd December 2010 02:16 AM |
| cannot figure out crossover | anwaypasible | Multi-Way | 28 | 7th August 2010 01:17 AM |
| Can Anyone figure this? | duderduderini | Tubes / Valves | 8 | 6th April 2008 01:27 PM |
| How to figure output Z of SRPP? | smbrown | Tubes / Valves | 13 | 12th January 2007 03:15 PM |
| help me figure this out please | xdissent | Solid State | 7 | 23rd November 2003 08:57 AM |
| Page generated in 0.06047 seconds (76.54% PHP - 23.46% MySQL) with 10 queries |
