Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
What's current "best" opamp for active filtering?
Old 30th April 2011, 04:23 PM   #1
sdad is offline sdad  United States
Default What's current "best" opamp for active filtering?
What's current "best" (maybe 2nd best, if cost is considered) opamp for line level active filtering, audio range? Home application, so standard bipolar +/- 15v supply is good. Either single or dual package good, quad, not so much.
Old 30th April 2011, 08:44 PM   #2
454Casull is offline 454Casull  Canada
You'll be hard-pressed to find somebody that can hear the audio signature of an OPA2134.
Old 30th April 2011, 08:47 PM   #3
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
LM4562!
Old 30th April 2011, 08:48 PM   #4
mbar is offline mbar  Poland
MC33078
Sent from my Milestone using Tapatalk
Old 1st May 2011, 07:13 AM   #5
Calvin is offline Calvin  Germany
Calvin's Avatar
as usual the answer is...it depends.
In this case it depends on the type of filter and the connected to it parts.
Generally the OP-Amp should not react much to different and varying impedances between their inputs. Gross impedance imbalances may lead to excessive output offsets. An example for such a situation are DC-servos/Integrator where one input sees 0Ohm while the other may see 1MOhm. FET-Input devices are less affected in this regard, because of their much lower input currents. If the source impedances the OPsees exceed ~2kOhms, FET-Input devices may be less noisy due to their much lower current noise. The typical FET-Input candidates are also all low enough in voltage noise for usage in low source impedance circuits.
In most filter applications the bandwidth limit of all OPamps exceeds the requirements by far. Very fast OPamps need more care regarding the power supply lines (hence PCB-layout and associated parts) than ´slower´ devices. So there´s in majority no necessity for fast wide bandwidth parts.
So if You are willing to mix technologies bipolar input OPamps may be suitable certain cases. If You want one device for all a FET-input OPamp should be Your choice.
If cost is a factor FET-devices like OPA604, OPA132, OPA134, or AD711, AD825(featuring a OPamp unusual high OL-bandwidth of >10kHz) and bipolars like the NE5534 or NJM4580 and their Dual and Quad brethren are suitable.
If cost is no object FETs like BB/TIs OPA627, OPA827, AnalogDevices´s AD743, AD8610 come to mind as well as the bipolar AD797 and some of the LME-Series of NationalSemi.
jauu
Calvin
Old 1st May 2011, 07:33 AM   #6
EUVL is offline EUVL  Europe
My choice in any case.
With modern FET input opamps, the noise advantage of BJT opamps becomes insignificant at line level.
> If cost is no object FETs like BB/TIs OPA627, OPA827, AnalogDevices´s AD743, AD8610 come to mind ...
You should try something modern like the OPA1641/2 for FET and OPA1611/2 for BJT.
And they are not even expensive.
Patrick
Old 1st May 2011, 07:38 AM   #7
If I were to use a Sallen Key with no gain, I basically only need a follower.
In such cases, I shall definitely use a pair of JFETs such as 2SK372 or 2SK369, as in :
http://www.diyaudio.com/forums/solid...er-module.html
Patrick
Old 1st May 2011, 07:53 AM   #8
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
NE5532 is best bang for the buck by a long way, so long as you're not asking for gain as well as filtering. If you are, then something with a bit more GBW would be appropriate - perhaps LM4562.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 25th March 2013, 09:44 PM   #9
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Patrick
Patrick and all,
Thanks for bringing the OPA164x series to my attention. Looking at the specs, these are very nice opamps for a good price. Of course, specs are good, but they don't always tell the whole story.
Has anyone compared the OPA1641/1642 to OPA627 for how they sound? The OPA627 is pricey, but my choice for high quality signal path opamps. It would be nice to get an opinion or two about how the OPA1641 compares.
Thanks in advance.
Jac
Old 26th March 2013, 02:14 AM   #10
Andersonix's Avatar
Because of the low distortion levels these new op amps have, one is closer than ever to listening to the ps quality.
What's current "best" opamp for active filtering?Hide this!Advertise here!
4-way Active (3+1 way) TL 15" 8" 3" 1" cka3o4nuk Multi-Way 44 25th April 2011 02:26 PM
Jfet/opamp "hybrid" phono stage 00940 Analogue Source 8 11th March 2011 06:29 PM
"A Continuous-Time Active Filter", AudioXpress Magazine, Aug 2010 Dr. Ram Analog Line Level 4 4th August 2010 03:15 AM
Comb Filtering from "mesh" pjpoes Multi-Way 11 14th March 2009 01:39 PM
Reconstruction filter from "Opamp applications" (Jung) 00940 Digital Source 7 10th November 2005 09:19 AM
Copyright ©1999-2017 diyAudio
