| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have just purchased eight DH Labs Ultimate RCA plugs and enough Pro Studio cable for two sets of interconnects, but I cannot figure how to attach the braid to the barrel of the plug in a way that will maintain proper operation of the locking sleeve.
I assume that the braid attaches to the slot in the barrel, but I can't get it threaded in there. Is it necessary to bend down the bar formed by the two slots so that the cable shield can slip into the gap, be crimped and soldered? I'm not a newbie, but I'm accustomed to cheap connectors with solder tabs. Thanks for any help anyone can give. |
#2 |
Custom Title
You're using a coaxial cable I take it? The bar is often used but is not my favorite (I've soldered some hundreds of the Ultimate RCAs, DARNED FINE choice of connector). Preferable is to make 2 little pigtails of approximately half the braid strands, one on either side of the cable (180 degrees from each other) and lay them along the top edge of the shell (the flat portion between the inside and the outside of the shell, parallel to the center pin). You'll have to pre-form them to get the cable to lay properly with the pigtail laid nicely up against that edge (it should be pressing against it). Be sure not to let them go further out (away from the center pin) than the outside cylendar of the body.
Use good strong solder, the cardas Quad Eutectic is very nice indeed and much stronger mechanically than some others. Also, take very good care with the strain relief, you don't want to stress these joints since they're only affixed via solder.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#3 |
Yes, I see what you mean.
BTW, do you solder directly to the gold plating, or do you scrape it off and solder to the copper substrate? |
| RCA SOCKETS DH-LABS CM-R1 or CMC? | SVI3206A | Parts | 0 | 12th February 2011 03:56 AM |
| DH LABS T-14 Silver Sonic Speaker cables | Livin | Swap Meet | 4 | 24th January 2009 03:21 PM |
| DH LABS T-14 Silver Sonic Speaker wire / cables | Livin | Swap Meet | 0 | 3rd January 2009 05:20 AM |
| DH Labs Silver Sonic Q10C Speaker Cable | bequerel | Swap Meet | 3 | 25th June 2004 02:32 PM |
| I need the ultimate PCB mount RCA femal plug. | Brian Guralnick | Parts | 5 | 3rd October 2003 06:06 PM |
| Page generated in 0.08022 seconds (71.23% PHP - 28.77% MySQL) with 10 queries |
