| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm building an active crossover right now and would like to use Vishay MKP filter capacitors, with a 5mm lead spacing. Digikey has some in stock, though they are rated for 25VAC / 63VDC. Is this AC voltage rating too low in anyone's opinion? I was hoping to get caps rated for 63VAC. part no. BFC241644703 Alternatively, does anyone have any recommendations for MKP's with a 5mm spacing? Thanks |
#2 |
25 Volts AC _across_ the cap in a crossover? I wouldn't expect even 5 V AC in normal operation. Look more if you feel the need but I'd use them without hesitation. You know that 25 Volt is almost 9 Volts RMS. A few power amps here don't get to 25 V p-p at the output much less the input.
G² |
#3 |
Okay thanks for the response.
The reason for the question was because Rod Eliot from ESP indicated that filter caps should be rated for 63V. I just wasn't sure if that was the DC or AC rating. I understand that the voltage levels will be very low (based on the gain of your input buffer, which is usually unity) but thought, perhaps, that people prefer using caps with a higher voltage rating because they sounded better. |
#4 |
I don't know about sounding better, and don't really want to go there. I may be wrong but I tend to think what you read from Mr. Elliot was within a certain context, eg a 5V supply and a 40V supply both need 63WVDC capacitors??
My rule of thumb (I say "my" but probably picked it up somewhere) is to add ~50% to whatever voltage I'm working with. More than that won't hurt and I second stratus46; I'd use those MKPs without hesitation.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#5 |
25 Vac = 63 Vp-p they are the same specs ie dielectric strength rating
most active solutions involve op-amps with +/- 15 supplies, which is about 30V pp max. so you already have 2 to 1 safety margin when using 63Vdc caps.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
| Capacitor Voltage Rating Question | Trout | Tubes / Valves | 11 | 5th June 2009 06:49 PM |
| Capacitor voltage rating in dots? | olev | Parts | 9 | 9th July 2007 07:41 AM |
| Capacitor Voltage Rating | diyman | Solid State | 2 | 21st December 2004 02:49 PM |
| Capacitor Voltage Rating | Super_BQ | Parts | 14 | 22nd September 2001 03:50 AM |
| Page generated in 0.08934 seconds (72.80% PHP - 27.20% MySQL) with 10 queries |
