diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   Smallest Dual Gang Potentiometer in the UK? (http://www.diyaudio.com/forums/parts/187371-dual-gang-potentiometer-uk.html)
gatekiller 19th April 2011 10:46 AM
Morning All,
I'm building a simple headphone amp that I want to fit inside a 2.5" hard drive enclosure. There's enough internal space to fit all the other components, however, I am having trouble finding a dual gang pot which is small enough.
The maximum internal height is 16mm and the height between the PCB and the top is even less at 10mm.
Are there any really tiny dual gang pots available in the UK?
Many Thanks
Stephen
PS: Here's an example of what the HDD enclosure looks like: http://www.asia.ru/images/target/pho..._Enclosure.jpg
They're very cheap to buy and most have a PCB mounting rail on the inside. They also come in a range of colours and finishes. The only downside is that most come with text written on the enclosure like "2.5 USB HDD Enclosure" but I can live with that and if it really bothers me, I could respray it.
digits 19th April 2011 11:40 AM
probably the little green alps ones from RS components....
Honestly I never bother with volume controls on portale headphone amps anymore, all the sources have volume controls.
gatekiller 19th April 2011 11:58 AM
@digits
Thanks for putting me in the right direction. As a result I found this:
Alps | Passives | Resistors | Trimmers, Potentiometer and Rheostat | Carbon Track |STRK97O7
It's a 10K Dual Gang 1 Turn Logarithmic Pot. It's main body height is 6.5mm which is just the size I need.
Chartal 19th April 2011 04:57 PM
The 6.5mm is from the base to center.
Total height is 6.5 + 4.85 = 11.35mm
digits 19th April 2011 05:13 PM
Originally Posted by gatekiller (http://www.diyaudio.com/forums/parts/187371-dual-gang-potentiometer-uk-post2543597.html#post2543597)
@digits
Thats the one, I'd order like 3 and check which one has the two channels tracking each other the closest....
chris661 19th April 2011 05:14 PM
I suppose with some clever gear wheels, you could mount the pot inside somewhere?
digits 19th April 2011 05:36 PM
1 Attachment(s)
here you go. P.S. you can try rubbing off the logo with sugar....
Resources saved on this page: MySQL 18.75%
