Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th April 2011, 03:13 PM   #1
Default Capacitor Question
I need a 210uf cap in my midrange crossover section. I know that a 150 and a 60 in parallel equals 210uf. How do audio frequencies react to parallel caps? Would there be a big difference if I went to one big cap compaired to the two smaller ones?
Old 18th April 2011, 03:48 PM   #2
sofaspud's Avatar
IMO no big difference.
How about a standard value 220uF that measures at the low side of its tolerance?
Old 18th April 2011, 06:40 PM   #3
I am currently using a 150uf np and a 65uf np in parallel. I was just wondering if audio acted differently than RF.
Old 18th April 2011, 11:33 PM   #4
Face is offline Face  United States
Face's Avatar
In my experience, splitting the values unevenly had a negative effect on imaging, YMMV.
"If it measures good and sounds bad, -- it is bad. If it sounds good and measures bad, -- you've measured the wrong thing." Daniel R. von Recklinghausen
Old 19th April 2011, 10:04 AM   #5
DF96 is offline DF96  England
Yes, audio is usually simpler than RF. Problems are only likely to arise if the capacitors are very different in value and very low ESR; then you might get a resonance.
Given normal manufacturing tolerances, I would just use a 220uF - perhaps selected if you are really fussy.
Capacitor Question mike49504 Car Audio 6 18th February 2011 05:18 PM
Capacitor question random007 Chip Amps 11 8th October 2010 10:37 AM
Capacitor question... Again and again... Dxvideo Chip Amps 14 9th January 2008 08:27 AM
capacitor question crippledchicken Solid State 3 31st October 2007 09:12 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
Page generated in 0.09558 seconds (72.11% PHP - 27.89% MySQL) with 10 queries
