Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th April 2011, 02:18 PM   #1
Default Heres a new trick
go to thrift stores and good will and buy up any old 28-56kmodems
The transformer inside is worth it
Tried and true
couples audio perfectly !
Old 16th April 2011, 03:39 PM   #2
sakis is offline sakis  Greece
sakis's Avatar
cant be right ....audio signals in telephony are limmited to something like 3KHZ or so ... i wonder though if this is limited by the trafo or other parts of the circiut ...yet again the ratio of winding might also be an issue
kind regards sakis
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 16th April 2011, 08:34 PM   #3
I am using it in my app right now and it sounds great !
Give it a try ok !
Old 16th April 2011, 08:49 PM   #4
600:600 transformers with very narrow bandwidth can behave much wider
when driven by low impedance <600 source into high impedance >600 load.
In this special case, not to your advantage to impedance match...
Assuming you desire the transformer only for balun and isolation.
Old 16th April 2011, 08:59 PM   #5
correctumundo
trick company dabeat The Lounge 0 7th October 2007 11:36 AM
Wewt new digi cam heres a pic 5th element Multi-Way 4 4th March 2004 07:38 PM
So heres what i decided on for the comp speakers, now how to connect? soundNERD Chip Amps 5 19th October 2003 02:42 PM
Page generated in 0.08219 seconds (73.69% PHP - 26.31% MySQL) with 10 queries
