Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd April 2011, 11:19 AM   #1
Default are series resistors a worse choice?
hi, i needed a 6ohm in the passive c/o for the tweeter circuit in my speakers but i only had 3ohms available to me at the time so i went and wired two of them in series to make it the desired value. they're mills 12W resistors. i was wondering if i'll see a sonic improvement by replacing them with one 6ohm resistor. thanks.
Old 3rd April 2011, 11:45 AM   #2
takayama69's Avatar
What is worst... a six meter cable or two three meters cables? Scientifically ther might be some disadvantage... but IRL probably no one could pick the difference. Ive seen Troels Gravesen and other gurus put resistors in series to get exactly 11,2 ohms from 2 5,6 ohms resistors in high level speakers. Good luck!
Old 3rd April 2011, 01:38 PM   #3
if you keep asking, you will find someone with a sharp ear who will tell you that this approach will destroy all fidelity possible, and more than likely is the responsble for the extinction of dinosaurs.
but as the above post says, there is no possible way you could tell the difference.
in many cases a crossover can have multiple resistors in series to get the required value, capacitors in parallel to get the required capacitance, and so on.
I seen one that uses 4 resistors in series-paralell to get proper power handling.
so no problem with that approach.
Old 3rd April 2011, 04:04 PM   #4
Probably a better choice!
Old 7th April 2011, 09:47 PM   #5
18Hurts is offline 18Hurts  United States
If I'm building a crossover, I parallel resistors to increase power handling if I can't get the exact value. (why not?)
I would not worry about the additional solder connection--think of the hundreds and thousands of them on a D to A converter board!
The every so slight resistance increase will be negated as soon as the voice coil starts moving so slap that sucker in series and have a cold one.
valve rectifier series resistors chokesrule Tubes / Valves 22 2nd June 2011 11:29 PM
Series Resistors on Outputs of Transformer? Magz Tubes / Valves 10 21st July 2010 08:57 PM
capacitors in series- what value balancing resistors? tmhajw Tubes / Valves 6 20th December 2008 06:19 PM
Info on Resistors / series resistance one1speed Full Range 7 24th February 2006 01:29 PM
resistors in series starrman93306 Car Audio 6 8th November 2004 08:56 PM
Page generated in 0.07949 seconds (70.48% PHP - 29.52% MySQL) with 10 queries
