looking for toroidal equivelant to transformer - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th August 2003, 05:37 AM   #1
Default looking for toroidal equivelant to transformer
i have built two kit amps and run them on their own transformers and power supply circuits.
the kits are here: http://www1.jaycar.com.au/productVie...=&SUBCATID=557
basically, the transformers are CT 28v secondaries (240v primary). the power supply kits output +/-40v. the way this works etc is of no problem to me, i understand all the theories.
now i'm also guessing that if i buy a toroidal that has two secondaries of 25v, i can wire them in series, with say wire A of the first secondary being 'negative' 25v, wire B of the first and wire A of the second being 0v, and wire B of the second being 'positive' 25v. but that's about 6vrms less power i'm feeding it. that means less power, doesn't it? i don't think i'll find a toroidal of 28v secondaries, but i don't know wether i'll be able to find one with 30v secondaries either (which i guess the amp SHOULD be able to handle).
my main reasons for changing to a toroidal are:
- magnetic fields
- single toroidal for 2 channel amp
- lower profile
I would really appreciate any help. i also realise it is basically impossible to tell me whether the amp will be able to handle more than 28v CT, and the power supply for that matter too, but i am willing to take a slight risk.
Old 4th August 2003, 05:59 AM   #2
Send a message via AIM to travis
http://www.toroid.com/standard_trans...rmers_117V.htm
donuts
Old 4th August 2003, 12:36 PM   #3
If you use a single transformer, on the SC480 , still use 1 bridge and set of filters per channel. rather then one set and then split the DC rails off to each amp.
Old 4th August 2003, 01:14 PM   #4
cheers man, but yeah i had figured that.
found a toroidal, 30v+30v 300VA, should do fine considering the transformers are rated at 28v CT 135VA. would have been cheaper to buy this toroidal straight up too, but i guess now i have two spare transformers
Old 7th August 2003, 05:19 AM   #5
Greg Erskine's Avatar
Hi phreeky82,
Here is where I get my toroids in Sydney.
http://ourworld.compuserve.com/homepages/harbuch/
I bought two 28VAC 160VA two weeks ago at $40.90 each plus GST. The frieght may be expensive though?
They have a large range and have hundreds in stock. I bought about 8 so far and have been very happy with the product. Cheaper and better than Jaycar, Dick Smith etc.
Greg Erskine
Toroidal transformer for F1 milezone Pass Labs 7 24th September 2009 09:23 AM
Toroidal transformer Ghianni Power Supplies 8 15th November 2006 04:44 PM
where to buy a toroidal transformer zafira1981 Power Supplies 2 13th December 2005 12:46 AM
FS: 18-0-18v Toroidal Transformer and More... Maples Swap Meet 12 7th August 2004 12:44 PM
toroidal transformer djdamix Parts 3 15th June 2004 08:11 PM
Copyright 1999-2017 diyAudio
